udara
How To Reduce Delay When Changing Omxplayer Resolution
Sun Sep 07, 2014 9:32 am
I'm using Raspbian on my RPi, first I start a omxplayer instance using following command
omxplayer --win '0 0 1920 1080' --dbus_name org.mpris.MediaPlayer2.omxplayer1 udp://224.1.1.1:1234
Then occasionally I need to open another omxplayer instance, before that I need to change "org.mpris.MediaPlayer2.omxplayer1" resolution 1920*880 (or any) so I use
bash dbuscontrolm.sh org.mpris.MediaPlayer2.omxplayer1 setvideopos 0 0 1920 880
This works fine but the problem is this take about 4 seconds to change resolution but I need to change resolution quickly as possible.
Is this the only way to do this or is there any different method to do this? need help
Thanks.
gkreidl
Re: How To Reduce Delay When Changing Omxplayer Resolution
Sun Sep 07, 2014 10:35 am
It's very much faster on http streams or local files. Changing resolution requires a seek command and this might be harder on udp streams.
Minimal Kiosk Browser (kweb)
udara
Sun Sep 07, 2014 11:05 am
Yes I checked with local files, compare to udp stream changing resolution of local file is really fast. Is there any other way to do this other than using dbus command.
Thanks.
gkreidl
Sun Sep 07, 2014 11:49 am
udara wrote:Yes I checked with local files, compare to udp stream changing resolution of local file is really fast. Is there any other way to do this other than using dbus command.
Thanks.
No
