Using a VGA Converter - Icons showing as being too large!
Posted: Sat Sep 06, 2014 11:29 am
Dear all,
I am new to Raspberry Pi and a bit of a technophobe so excuse my ignorance!!
I am using my Raspberry Pi together with an old Dell Monitor from work - the Dell E1912H. Anyway, I've read that the max resolution on this monitor should be 1366 x 768 pixels.
I bought an HDMI-VGA converter for the monitor. Connected it to the Raspberry Pi, set up the SD card etc, and it didn't work.
Anyway I made some adjustments to the Config based on the information that I'd Googled and managed to get the monitor working.
The problem now, is that the resolution/icons are all huge.
I've tried to adjust a few things in the Config.txt but while this has made everything a more reasonable size, the resolution is now bad.
Please see my Command text below:
Thanks so much
Can anyone help?# uncomment if you get no picture on HDMI for a default "safe" mode
hdmi_safe=1
disable_overscan=0
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
framebuffer_width=1366
framebuffer_height=768
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=16
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# for more options see http://elinux.org/RPi_config.txt
Thanks so much
