justinbaron
Startx crashes
Sun Jun 17, 2012 10:17 am
photo (6).JPG (37.46 KiB) Viewed 2899 times
Hi
I am struggling to get going.
I have successfully installed and logged into Debian Squeeze but can't get the GUI to run.
Attached is a screen shot of the error messages. As you can see I have tried it in Root too.
The GUI does seem to flash up very briefly. If I type in startx a second time the whole thing just hangs with a black screen.
Any help would be gratefully received !
4GB SD card only 43% full
jecxjo
Re: Startx crashes
Sun Jun 17, 2012 3:59 pm
Did you manually configure your xorg setup? Also could you post /var/log/Xorg.0.log as it will provide more details to your error.
xmpp: jecxjo@dukgo.com
Blog: http://jecxjo.motd.org/code
Richard_P
Re: Startx crashes
Sun Jun 17, 2012 4:08 pm
after logging in... type
sudo gdm
That will launch the GUI login manager.
justinbaron
Re: Startx crashes
Sun Jun 17, 2012 4:35 pm
jecxjo wrote:Did you manually configure your xorg setup? Also could you post /var/log/Xorg.0.log as it will provide more details to your error.
Many thanks for helping me out.
I used RasPiWrite to install from my Mac.
When I type in var/log/Xorg.0.log I get the following error:
-bash: /var/log/Xorg.0.log: permission denied
justinbaron
Re: Startx crashes
Sun Jun 17, 2012 4:41 pm
Richard_P wrote:after logging in... type
sudo gdm
Thanks I will give it a go
jecxjo
Re: Startx crashes
Sun Jun 17, 2012 5:16 pm
Sorry, I mean can you copy the contents of that file into the forum? Log in as root and do the following:
mount /dev/sda1 /mnt
cp /var/log/Xorg.0.log /mnt
umount /mnt
Then plug in the stick into your desktop and post the text here.
