Deluge Web UI Setup
Posted: Tue Sep 02, 2014 11:48 am
I’ve successfully gone through the torrent box tutorial, but I’m stuck on the deluge web UI.
http://www.howtogeek.com/142044/how-to- ... rrent-box/
To install the WebUI, go to the terminal on your Pi and enter the following commands. Note: If you already installed the Deluge daemon in the ThinClient section of the tutorial, skip the first command here.
The issue is running “deluge-web” – this command makes the terminal session hang. The web UI is useable though, I can log in and use the UI, change password etc. But cannot then move on to the next stage of the tutorial to edit the web.conf file as it never gets created. I would like to edit the port number to 8080, which I can’t do through the web UI.
this is the error message
Any help would be great, cheers
sudo apt-get install deluged
sudo apt-get install python-mako
sudo apt-get install deluge-webCode: Select all
deluge-webthis is the error message
File "/usr/bin/deluge-web", line 9, in <module>
load_entry_point('deluge==1.3.3', 'console_scripts', 'deluge-web')()
File "/usr/lib/python2.7/dist-packages/deluge/ui/web/web.py", line 138, in start
web.start()
File "/usr/lib/python2.7/dist-packages/deluge/ui/web/web.py", line 125, in start
self.server.start()
File "/usr/lib/python2.7/dist-packages/deluge/ui/web/server.py", line 665, in start
self.start_normal()
File "/usr/lib/python2.7/dist-packages/deluge/ui/web/server.py", line 673, in start_normal
self.socket = reactor.listenTCP(self.port, self.site)
File "/usr/lib/python2.7/dist-packages/twisted/internet/posixbase.py", line 436, in listenTCP
p.startListening()
File "/usr/lib/python2.7/dist-packages/twisted/internet/tcp.py", line 641, in startListening
raise CannotListenError, (self.interface, self.port, le)
twisted.internet.error.CannotListenError: Couldn't listen on any:8112: [Errno 98] Address already in use.Any help would be great, cheers
