Totaly new - My First Project - What do i need?
Posted: Sun Aug 31, 2014 10:48 am
by MasseElch
i'm a proud new owner of my very first and very own Pi for half an our now :shock:
AND, what to do now?
I already have experiance with webDevelopment (and a lot of that). SO i hope i can start working with my pi without lots of struggle.
For my first Project i want my Pi to load data from my MySQL and display it on a big TV-Screen.
I jsut dont know where to start. There are so much Os's i could use. I just want to ask for some hints how to start, what to read, which tutorial to use, so i find an easy quick and nice way to start with my pi.
What can you guys recommend. Where to start?
Regards,
MasseElch
Re: Totaly new - My First Project - What do i need?
Posted: Sun Aug 31, 2014 10:53 am
by DougieLawson
Start with a NOOBS SDCard and choose Raspbian as your OS.
http://www.raspberrypi.org/downloads/
http://www.raspberrypi.org/help/noobs-setup/
Posted: Sun Aug 31, 2014 11:02 am
by fruitoftheloom
MasseElch wrote:Hello,
Regards,
MasseElch
Personally use Raspbian Wheezy Standalone on an 8GB SD Card class4 http://www.raspberrypi.org/downloads
MYSQL. http://raspberrywebserver.com/sql-datab ... ry-pi.html
Posted: Sun Aug 31, 2014 11:20 am
by DougieLawson
fruitoftheloom wrote: Personally use Raspbian Wheezy Standalone on an 8GB SD Card class4 http://www.raspberrypi.org/downloads
That's not good advice for the new user who has never booted a Linux system before. NOOBS is designed to be foolproof (if the simple instructions are followed) as it needs nothing other than stock, standard Windows programs to create a bootable SDCard. Using the stand-alone image is more complex and, therefore, more prone to failure.
Posted: Sun Aug 31, 2014 11:28 am
by mahjongg
you could do worse than by starting reading here: Help, Resource and Technical Documents
Posted: Sun Aug 31, 2014 11:52 am
by fruitoftheloom
We can agree to disagree, you are not a Moderator so will take what you say with a pinch of salt :shock:
Posted: Sun Aug 31, 2014 11:53 am
by MasseElch
Forgot to say: im familiar with Linux. Im using Ubunut and Arch for about 4 years now.
Thanks to all so far for the links. :-)
Posted: Sun Aug 31, 2014 1:18 pm
by DougieLawson
In that case follow Fruity's advice and go with the Raspbian image. Use
dd if=/tmp/raspbian.img of=/dev/sdb bs=50M &
on your Ubuntu system to write it to the card.
Posted: Sun Aug 31, 2014 6:59 pm
by MasseElch
Will try it.
And i will keep you updated bout progress :-)
Im so F**** ECXITED :-)
Posted: Mon Sep 01, 2014 1:27 pm
by pluggy
fruitoftheloom wrote: We can agree to disagree, you are not a Moderator so will take what you say with a pinch of salt :shock:
Moderator doesn't make the cut with me, there are some experienced users I'd rank above some Mods. Dougie is one such although he is more of a NOOBS fan than I am. The plain old Raspdian image install is ALWAYS the way to go with me......
Posted: Mon Sep 01, 2014 1:33 pm
by DougieLawson
pluggy wrote: Moderator doesn't make the cut with me, there are some experienced users I'd rank above some Mods. Dougie is one such although he is more of a NOOBS fan than I am. The plain old Raspdian image install is ALWAYS the way to go with me......
I'm only a promoter of NOOBS for the intended user base. I won't choose to use it on my own systems unless I'm testing something for a MagPi magazine article (yes, I'm part of the MagPi's editorial team). The best install is raspbian-ua-netinst which gets Raspbian running with none of the bloated stuff I don't need. One of my RPis is running a Raspbian image (upgraded to Jessie), the other is running the NOOBS image from http://fuze.co.uk with Notro's FBTFT drivers on top of that.
Posted: Mon Sep 01, 2014 1:49 pm
by pluggy
I'm old school, none of this new-fangled net install stuff, I use a script to butcher the full Raspdian to get shut of the X bloat. Always Raspdian because its next door to Ubuntu and I've always liked Ubuntu.
Real Canonical fanboy me..... :mrgreen:
Posted: Wed Sep 03, 2014 1:58 am
by AndrewS
MasseElch wrote:Forgot to say: im familiar with Linux. Im using Ubunut and Arch for about 4 years now.
If you've already got a bit of Linux knowledge, then take a look at
http://www.raspberrypi.org/documentation/usage/
http://www.themagpi.com/
amongst others as great starting-off points 8-)
Posted: Mon Sep 08, 2014 12:58 pm
by MasseElch
Hello there,
got Raspbian working on my PI.
Now what i want to do:
I have an MySQL databse on another server running with data. I want the PI to show it on a big TV.
I can now write an php/html/jquery/css script and open it in epiphany or another browser or i use Java or C++ or sth else. (Maybe Python, don know that language yet).
What do you recommend?
What gives the best performance?
Lg
MasseElch
PS: AAAAND what do you guys think about Arch? There is a lot of stuff on the raspbian i dont rly need (wolfram just to mention one). So it took me awhile to "clean up" the installation
Posted: Mon Sep 08, 2014 10:37 pm
by DougieLawson
If you're an existing Linux user then Arch may be for you (when I tried it I found it very weird, compared to OpenSuSE, Ubuntu and DebIan (aka Raspbian)).
If not then raspbian-ua-netinst is a good tool to get a minimal installation (bare essentials plus just the packages you choose, no bloat).
With MySQL on another machine you'll need the mysql-client package on your Raspbian system. Update the "remote" MySQL server to make sure it is listening on the 0.0.0.0 address (because it defaults to localhost). Add a new id with privileges to the tables you want to use on your RPi and allow any machine on your local subnet (192.168.xxx.yyy) to connect.
