Riverstorm
Running a perl script with parameters in a file
Tue Aug 26, 2014 5:59 pm
I've been trying to figure out if it's possible to run a perl script with parameters from a "batch" file so I don't have to type the whole command every time. I tried several things but I can't seem to figure it out. Here's the command. Is it possible to put it into like an executable file or batch file to run if that makes sense? It's a scraper that associates screenshots with games. Any help would be greatly appreciated. Thank you.
perl mameGenXml.pl -rompath /home/pi/mame4all/roms/ -mode mame -extension zip > gamelist.xml
Re: Running a perl script with parameters in a file
Tue Aug 26, 2014 6:07 pm
Wrap a shell script round it.
#!/bin/bash
/usr/bin/perl mameGenXml.pl -rompath /home/pi/mame4all/roms/ -mode mame -extension zip > gamelist.xml
Riverstorm
Tue Aug 26, 2014 9:10 pm
Ok, I will give that a try. Should I also add the full path to the MameGenXml.pl part of the command (i.e. - /home/pi/genScript/mameGenXml.pl) or is that not needed or is it good practice to do it?
Tue Aug 26, 2014 9:14 pm
It depends how you're planning to run the script. If you're in a normal shell you'll inherit the normal environment, if you're running from crontab you run in a limited environment. It can be a good idea to include full paths.
Riverstorm
Tue Aug 26, 2014 9:47 pm
Ok, I don't quite understand that but I tried it both ways with the path added and without but I get the same error from the script with a different path. I am in the directory where all the files are located too.
It does run fine outside the file just from a shell. I also made it an executable with chmod +x mame (mame is the file I created).
readdir() attempted on invalid dirhandle DIR at /home/pi/genScript/mameGenXml.pl line 51.
closedir() attempted on invalid dirhandle DIR at /home/pi/genScript/mameGenXml.pl line 52.
readdir() attempted on invalid dirhandle DIR at mameGenXml.pl line 51.
closedir() attempted on invalid dirhandle DIR at mameGenXml.pl line 52.
Do I need to enclose the parameters in quotes or something?
AndrewS
Tue Aug 26, 2014 10:26 pm
Sounds like there's a bug in the mameGenXml.pl script - it's not checking to see if the directory exists before opening it (which is why you're getting the 'invalid dirhandle' errors). Double-check the paths you're giving as arguments to the perl script actually exist.
Riverstorm
Wed Aug 27, 2014 10:51 pm
Thanks Dougie and Andrew, the command worked perfectly and I also did have a typo in the path. I really appreciate the help as it will save a ton of keystrokes! :)
