Resolution on LXDE Higher than 1554x984?
Posted: Sat Jun 16, 2012 1:44 am
by D.E.L.B.
Hey,
For some reason I can't seem to get the resolution to go to my desired resolution of my monitor, which is: 1680x1050.
I've tried looking for the xorg.conf file but I can't seem to find that, and I've also tried to force the resolution with config.txt, but that seems to have made no difference with LXDE.
Any suggestions, please?
Re: Resolution on LXDE Higher than 1554x984?
Posted: Sat Jun 16, 2012 8:57 am
by dom
Posted: Sat Jun 16, 2012 2:07 pm
by D.E.L.B.
Thanks!
For all those who have a Samsung 19" monitor, then these are the settings that I used:
overscan_top=-45
overscan_bottom=-45
overscan_left=-45
overscan_right=-45
Posted: Mon Jun 18, 2012 12:43 am
by D.E.L.B.
I'd also like to say that at first I thought when you installed Debian onto the SD card, it would have a config.txt on there, but it turns out you have to create the config.txt file yourself with a text editor like "Notepad" on Windows... or with "Nano" on Linux.
With "Notepad" it's quite simple, open it up, add the above ^^ settings to the file, save it as > config.txt.
Then with doing it on Linux on bootup within the CLI, use:
"sudo nano /boot/config.txt" - a blank area of that file will be present.
Enter the above settings ^^, press CTRL+O at the same time, then it will save. Press CTRL+ALT+DEL to reboot the Pi.
Posted: Mon Jun 18, 2012 2:05 am
by AndrewS
D.E.L.B. wrote:Press CTRL+ALT+DEL to reboot the Pi.
It's generally considered better to do a "sudo reboot" (since that also works over e.g. SSH)
