NotARacistK
What should I do with my Pi?
Tue Aug 19, 2014 2:48 pm
I would love to hook up some displays, batteries, camera, bla bla bla... so I can use it as a portable linux machine. :D
A1i2T3R
Re: What should I do with my Pi?
Tue Aug 19, 2014 3:37 pm
ok so you want a portable linux device?
May I point you to this article in makeazine for some inspiration.
http://makezine.com/2014/01/07/how-i-bu ... pi-tablet/
Enthusiastic pi user, with a hoby for modding everyday objects and using the pi as the brain!
AndrewS
Tue Aug 19, 2014 4:31 pm
NotARacistK
Thu Aug 21, 2014 5:49 am
So... quick checklist in my goals:
1. Pi B+ (Done)
2. USB battery thing that gives 5V 2A (Done)
3. (Touch) Screen that runs off HDMI power or the display socket in the pi (didn't want to say display port as people might think I said DisplayPort) (That will be hard)
4. Small keyboard & Trackpad/Mouse (Hard too)
5. The PS/2 keyboard with that awesome "Enter" Key (Done)
6. I wonder if I can connect my Pi to the computer through micro USB.
7. Micro USB cable... do I need an explanation?
8. A case (Got the PiBow... won't fit a LCD screen.)
9. Minecraft Pi Edition (Done)
10. MicroSDXC for Pi (64GB or bigger ... any recommendations? or will it not work at all?)
Thu Aug 21, 2014 6:46 am
NotARacistK wrote:6. I wonder if I can connect my Pi to the computer through micro USB.
Only for power, and even then your computer may not supply enough if it limits the USB port to 500mA (some do).
BMS Doug
Thu Aug 21, 2014 8:16 am
NotARacistK wrote: 3. (Touch) Screen that runs off HDMI power or the display socket in the pi (didn't want to say display port as people might think I said DisplayPort) (That will be hard)
What's wrong with the many GPIO powered touchscreens?
what size of screen are you looking for?
NotARacistK wrote: 10. MicroSDXC for Pi (64GB or bigger ... any recommendations? or will it not work at all?)
also consider a mini USB memory stick.
11. WIFI dongle?
Doug.
NotARacistK
Thu Aug 21, 2014 1:36 pm
Forgot about that. :D btw I am looking for a 4"-5" (Size of a Galaxy S3's screen) display that does 480/576/720p... a bigger PiTFT? xd
I like storing things inside the OS's drive.
11. WIFI dongle?
Oh yeah. I got: A 64GB USB, WiFi, and BT (maybe for connecting a small keyboard&Mouse?)
BMS Doug
Thu Aug 21, 2014 3:00 pm
here are some screen options.
4.3" touchscreen $144 (seems expensive) (no resolution description)
7" touchscreen $60 only 800x480 resolution
5.6" 720p (not sure if its got touchscreen) $150
Doug.
Andrew_ww
Thu Aug 21, 2014 5:03 pm
Ppl is it possible to use rasp as a mass storage device? There is a micro-b connector on rp b+, is that a fully functional client usb connector, or is that a power-purpose connector only? Thx
Thu Aug 21, 2014 5:54 pm
Andrew_ww wrote:Ppl is it possible to use rasp as a mass storage device? There is a micro-b connector on rp b+, is that a fully functional client usb connector, or is that a power-purpose connector only? Thx
NotARacistK
Fri Aug 22, 2014 2:28 pm
I think it's the hardware limitations that only connects Power+ and Power- into the pin... maybe?
maybe they will add it in Pi 2.
AndrewS
Fri Aug 22, 2014 3:12 pm
It's not quite the same as what you're looking for, but maybe http://www.raspberrypi.org/jayme-gisbournes-porta-pi/ will give you some ideas too :?:
NotARacistK
Sat Aug 23, 2014 12:43 am
AndrewS wrote:It's not quite the same as what you're looking for, but maybe http://www.raspberrypi.org/jayme-gisbournes-porta-pi/ will give you some ideas too :?:
Nope, very simillar to what I want.
BTW I wonder if my Pi can even read battery stats.
AndrewS
Sun Aug 24, 2014 4:27 pm
NotARacistK wrote:BTW I wonder if my Pi can even read battery stats.
http://www.raspberrypi.org/forums/viewt ... 37&t=84624
