repulse
Issue with WD My Passport 2To
Thu Aug 14, 2014 5:49 pm
Hi, my Pi (B+) is ready to rock, with Xbian, but i can't get my external hard drive to work, even with Y-usb cable. Not detected.
Is there an other way than usb-powered hub, or i absolutely need it ?
Cheers !
fransko
Re: Issue with WD My Passport 2To
Thu Aug 14, 2014 5:55 pm
try this
tail -f/var/log/messages
sudo fdisk -l
-t ntfs -3g (windows drive)
umount voor loskoppelen disk
repulse
Thu Aug 14, 2014 6:47 pm
fransko wrote:try this
sudo fdisk -l
With HDD plugged in ? And can i do it via ssh ?
DirkS
Thu Aug 14, 2014 9:19 pm
sudo fdisk -l
Sorry, but that does not make a lot of sense to me. There are partial commands: '-t ntfs...'. That should probably have 'sudo mount ' in front of it.
Furthermore you assume it's a NTFS drive and there's a space in the driver name.
You have also thrown a bit of Dutch into it ('voor loskoppelen disk' --> 'to disconnect drive').
repulse wrote: but i can't get my external hard drive to work, even with Y-usb cable. Not detected.
How have you checked? Did you use 'lsusb', which should give you all the USB devices.
If it is listed with lsusb you can use dmesg to see if a device is assigned. It should look something like this, but of course you could have an error message there
[ 3.697744] usb 1-1.2.3: new high-speed USB device number 5 using dwc_otg
[ 3.801019] usb 1-1.2.3: New USB device found, idVendor=0480, idProduct=a009
[ 3.809953] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.819247] usb 1-1.2.3: Product: External USB 3.0
[ 3.825772] usb 1-1.2.3: Manufacturer: TOSHIBA
[ 3.831974] usb 1-1.2.3: SerialNumber: 22222831222C
[ 3.839544] usb-storage 1-1.2.3:1.0: USB Mass Storage device detected
[ 3.848343] scsi0 : usb-storage 1-1.2.3:1.0
[ 6.882786] scsi 0:0:0:0: Direct-Access TOSHIBA External USB 3.0 0201 PQ: 0 ANSI: 6
[ 6.895817] sd 0:0:0:0: [sda] 1953525164 512-byte logical blocks: (1.00 TB/931 GiB)
[ 6.906923] sd 0:0:0:0: [sda] Write Protect is off
[ 6.913773] sd 0:0:0:0: [sda] Mode Sense: 2f 00 00 00
[ 6.914447] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 6.936249] sda: sda1
The file system can eventually be important, but of no importance if the usb device is not detected.
Gr.
Dirk.
repulse
Thu Aug 14, 2014 10:01 pm
I didn't really checked, it just don't appear anywhere but i haven't used the 'lsusb' command..
Will try tomorrow and tell you what happend.
Cheers !
repulse
Fri Aug 15, 2014 10:02 am
So,
pi@raspbmc:~$ lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystem Corp.
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0424:ec00 Standard Microsystem Corp.
Bus 001 Device 005: ID 1058:0748 Western Digital Technologies, Inc.
Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp.
pi@raspbmc:~$
It appear to be there, but can't see it..
(PS: My HDD is usb-powered)
pi@raspbmc:~$ dmesg
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpu
Linux version 3.12.21 (root@samnazarko-compiler) (gcc version 4.7.1 20120402 (pr erelease) (crosstool-NG 1.15.2) ) #2 PREEMPT Wed Jun 11 04:53:06 UTC 2014
CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: BCM2708
Memory policy: ECC disabled, Data cache writeback
On node 0 totalpages: 98304
free_area_init_node: node 0, pgdat c09ef22c, node_mem_map c0a43000
Normal zone: 768 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 98304 pages, LIFO batch:31
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 97536
Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1136 bcm2708_fb.fbhe ight=592 bcm2708.boardrev=0x10 bcm2708.serial=0x940e03d9 smsc95xx.macaddr=B8:27: EB:0E:03:D9 bcm2708.disk_led_gpio=47 bcm2708.disk_led_active_low=0 sdhci-bcm2708 .emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 root=/dev/mmcblk0p6 rootfstype=ext4 noatime quiet rootwai t loglevel=1 sdhci-bcm2708.enable_llm=1 dwc_otg.microframe_schedule=1 dwc_otg.fi q_fix_enable=0 dwc_otg.fiq_split_enable=0
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 379180K/393216K available (4939K kernel code, 214K rwdata, 604K rodata, 4379K init, 333K bss, 14036K reserved)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xd8800000 - 0xff000000 ( 616 MB)
lowmem : 0xc0000000 - 0xd8000000 ( 384 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc0571ffc (5544 kB)
.init : 0xc0572000 - 0xc09b8d5c (4380 kB)
.data : 0xc09ba000 - 0xc09ef940 ( 215 kB)
.bss : 0xc09ef94c - 0xc0a42fe9 ( 334 kB)
Preemptible hierarchical RCU implementation.
NR_IRQS:394
sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
Switching to timer-based delay loop
Console: colour dummy device 80x30
console [tty0] enabled
Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Initializing cgroup subsys bfqio
CPU: Testing write buffer coherency: ok
Setting up static identity map for 0xc04d8b60 - 0xc04d8bbc
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
NET: Registered protocol family 16
DMA: preallocated 4096 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
bcm2708.uart_clock = 0
mailbox: Broadcom VideoCore Mailbox driver
bcm2708_vcio: mailbox at f200b880
bcm_power: Broadcom power driver
bcm_power_open() -> 0
bcm_power_request(0, 8)
bcm_mailbox_read -> 00000080, 0
bcm_power_request -> 0
Serial: AMBA PL011 UART driver
dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Switched to clocksource stc
FS-Cache: Loaded
CacheFiles: Loaded
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
bcm2708_dma: DMA manager at f2007000
bcm2708_gpio: bcm2708_gpio_probe c09c61f0
vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
FS-Cache: Netfs 'nfs' registered for caching
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
msgmni has been set to 740
Key type asymmetric registered
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered
io scheduler bfq registered (default)
BFQ I/O-scheduler version: v7r4
BCM2708FB: allocated DMA memory 56ed0000
BCM2708FB: allocated DMA channel 0 @ f2007000
Console: switching to colour frame buffer device 142x37
uart-pl011 dev:f1: no DMA platform data
brd: module loaded
loop: module loaded
vchiq: vchiq_init_state: slot_zero = 0xd8804000, is_master = 0
bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver smsc95xx
usbcore: registered new interface driver cdc_ncm
dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Core Release: 2.80a
Setting default values for core params
Finished setting default values for core params
Using Buffer DMA mode
Periodic Transfer Interrupt Enhancement - disabled
Multiprocessor Interrupt Enhancement - disabled
OTG VER PARAM: 0, OTG VER FLAG: 0
Dedicated Tx FIFOs mode
WARN::dwc_otg_hcd_init:1042: FIQ DMA bounce buffers: virt = 0xd8c27000 dma = 0x5 6f18000 len=9024
FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
dwc_otg: Microframe scheduler enabled
WARN::hcd_init:473: FIQ at 0xc037ce44
WARN::hcd_init:474: FIQ ASM at 0xc037d0f8 length 36
WARN::hcd_init:500: MPHI regs_base at 0xd8c1c000
dwc_otg bcm2708_usb: DWC OTG Controller
dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
Init: Port Power? op_state=1
Init: Power Port (0)
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: DWC OTG Controller
usb usb1: Manufacturer: Linux 3.12.21 dwc_otg_hcd
usb usb1: SerialNumber: bcm2708_usb
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
dwc_otg: FIQ enabled
dwc_otg: NAK holdoff enabled
dwc_otg: FIQ split-transaction FSM enabled
Module dwc_common_port init
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.26.0-ioctl (2013-08-15) initialised: dm-devel@redhat.com
bcm2835-cpufreq: min=850000 max=850000 cur=850000
bcm2835-cpufreq: switching to governor ondemand
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci: Enable low-latency mode
mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
sdhci-pltfm: SDHCI platform and OF driver helper
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
zram: Created 1 device(s) ...
TCP: westwood registered
Initializing XFRM netlink socket
NET: Registered protocol family 17
Key type dns_resolver registered
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Freeing unused kernel memory: 4376K (c0572000 - c09b8000)
mmc0: new high speed SDHC card at address e624
mmcblk0: mmc0:e624 SU08G 7.40 GiB
mmcblk0: p1 p2 < p5 p6 > p3
Indeed it is in host mode hprt0 = 00021501
usb 1-1: new high-speed USB device number 2 using dwc_otg
Indeed it is in host mode hprt0 = 00001101
usb 1-1: New USB device found, idVendor=0424, idProduct=9514
usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 5 ports detected
usb 1-1.1: new high-speed USB device number 3 using dwc_otg
usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
smsc95xx v1.0.4
smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx US B 2.0 Ethernet, b8:27:eb:0e:03:d9
usb 1-1.5: new high-speed USB device number 4 using dwc_otg
usb 1-1.5: New USB device found, idVendor=0bda, idProduct=8179
usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.5: Product: 802.11n NIC
usb 1-1.5: Manufacturer: Realtek
usb 1-1.5: SerialNumber: 00E04C0001
EXT4-fs (mmcblk0p6): recovery complete
EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
udevd[122]: starting version 175
bcm2708_i2c_init_pinmode(0,0)
bcm2708_i2c_init_pinmode(0,1)
bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 1000 00)
bcm2708_i2c_init_pinmode(1,2)
bcm2708_i2c_init_pinmode(1,3)
bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 1000 00)
bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
usbcore: registered new interface driver r8188eu
pcm512x 1-004c: Failed to reset device: -5
pcm512x: probe of 1-004c failed with error -5
EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
FAT-fs (mmcblk0p5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
bcm2835-cpufreq: switching to governor performance
ip_tables: (C) 2000-2006 Netfilter Core Team
nf_conntrack version 0.5.0 (5993 buckets, 23972 max)
Console: switching to colour dummy device 80x30
NET: Registered protocol family 10
smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
MAC Address = e8:94:f6:24:50:26
IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
R8188EU: ERROR assoc success
IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
EXT4-fs (mmcblk0p3): recovery complete
EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
bcm2708 watchdog, heartbeat=10 sec (nowayout=0)
usb 1-1.4: new high-speed USB device number 5 using dwc_otg
usb 1-1.4: New USB device found, idVendor=1058, idProduct=0748
usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=5
usb 1-1.4: Product: My Passport 0748
usb 1-1.4: Manufacturer: Western Digital
usb 1-1.4: SerialNumber: 575844314533334C4D414836
usb-storage 1-1.4:1.0: USB Mass Storage device detected
scsi0 : usb-storage 1-1.4:1.0
scsi 0:0:0:0: Direct-Access WD My Passport 0748 1022 PQ: 0 ANSI: 6
sd 0:0:0:0: [sda] Spinning up disk...
scsi 0:0:0:1: Enclosure WD SES Device 1022 PQ: 0 ANSI: 6
................................................................................ ....................not responding...
sd 0:0:0:0: [sda] READ CAPACITY failed
sd 0:0:0:0: [sda]
Result: hostbyte=0x00 driverbyte=0x08
sd 0:0:0:0: [sda]
Sense Key : 0x2 [current]
sd 0:0:0:0: [sda]
ASC=0x4 ASCQ=0x1
sd 0:0:0:0: [sda] Test WP failed, assume Write Enabled
sd 0:0:0:0: [sda] Asking for cache data failed
sd 0:0:0:0: [sda] Assuming drive cache: write through
................................................................................ ...................not responding...
sd 0:0:0:0: [sda]
sd 0:0:0:0: [sda]
sd 0:0:0:0: [sda]
ASC=0x4 ASCQ=0x1
sd 0:0:0:0: [sda] Attached SCSI disk
pi@raspbmc:~$
Fri Aug 15, 2014 12:30 pm
Though lsusb sees the drive conroller board, it may not be spinning up the drive..
The B+ has a default of 600ma on the USB Bus (4 x USB + 1 x Ethernet), I believe, many drives take more than this and could not find the details of the power draw of the Passport 2 TB drive but it seems to use only one USB Cable !
This may be worth reading if a mains powered hub also not supplying enough power:
https://projects.drogon.net/testing-set ... erry-pi-b/
Thinking outside the box is better than burying your head in the sand...
repulse
Fri Aug 15, 2014 12:39 pm
As i don't really want to modify the usb voltage, what do you think about this "hub" ?
Can it be used good ?
DirkS
Fri Aug 15, 2014 12:42 pm
repulse wrote:As i don't really want to modify the usb voltage
You don't change the voltage, you're increasing the maximum available power / amps to the USB ports. Your power supply will have to support it too though; you would need a 2A PSU.
what do you think about this "hub" ? Can it be used good ?
Which hub?
repulse
Fri Aug 15, 2014 12:45 pm
My bad, forgot the link !
https://www.modmypi.com/raspberry-pi-ac ... pi-usb-hub
and, increasing maximum available is really safe for the Pi ?
Fri Aug 15, 2014 12:50 pm
Can you inform us of the Power Requirements of the WD PassPort 2TB Drive, I know it is 5V but what is the amperage ?? is it written on the drive ??
default_user8
Fri Aug 15, 2014 1:17 pm
If its a WD Ultra(7200rpm)drive, you'll have to use a powered hub to run the drive. Then you shouldn't have any issues.
Two heads are better than one, unless one's a goat head.
Fri Aug 15, 2014 1:28 pm
default_user8 wrote:If its a WD Ultra(7200rpm)drive, you'll have to use a powered hub to run the drive. Then you shouldn't have any issues.
The title of the thread suggests it is a Western Digital Passport 2TB USB3.0 external USB drive !
repulse
I don't know the needed power but model is WDBY8L0020BBK-NESN
Fri Aug 15, 2014 1:36 pm
repulse wrote:I don't know the needed power but model is WDBY8L0020BBK-NESN
I looked on the WD website and could not find the power requirements :shock:
repulse
Fri Aug 15, 2014 1:59 pm
That's a problem :mrgreen:
default_user8
Fri Aug 15, 2014 4:04 pm
The"Ultra" line of WD usb drives use 7200 rpm drives, where as the regular WD line uses 5400 rpm drives. A 7200rpm drive would have a higher in rush of current than a 5400 drive which might be to much for a raspi to supply. If there isn't enough power the drive won't spin up and initialize, therefore it wouldn't be recognized by the pi, only the usb contoller would still be active. A powered usb hub will fix that, unless you just have a bad drive.
repulse
Fri Aug 15, 2014 4:16 pm
My drive is OK, it's recognized with all my others devices without any problem..
What i don't want in USB hub is to have additionnal câble.
default_user8
Fri Aug 15, 2014 5:30 pm
I understand, my setup is somewhat messy, but with 2 1TB drives i have to use a hub. I used some 1/4 lexan and some stand offs to make a stack, that helps but there is no avoiding having a PSU, data cable, power cable, and 2 drive cables.
repulse
Fri Aug 15, 2014 6:27 pm
OK, so i'll pick up a hub. Raspiado & UUgear seems good alternative, or https://www.modmypi.com/raspberry-pi-ac ... pi-usb-hub but i don't know if compatible with B+
default_user8
Fri Aug 15, 2014 7:33 pm
repulse wrote:OK, so i'll pick up a hub. Raspiado & UUgear seems good alternative, or https://www.modmypi.com/raspberry-pi-ac ... pi-usb-hub but i don't know if compatible with B+
Oh i like that second hub :P thats nice with the same footprint as the raspi i have to get one of those! It would fit in my stack right under my pi and shorten it some. Thanks for the link!
repulse
Fri Aug 15, 2014 8:28 pm
You're welcome :D
Which one ?
So, they can replace "normal" hub, and power hdd ?
default_user8
Fri Aug 15, 2014 9:35 pm
The "naked" hub is the same size as a raspi, and the holes are in the same locactions. I screwed stand offs from an old pc into the lexan squares i cut out to make my stack and then mounted the raspi to the stand offs. I'll get a "naked" hub and mount it where my pi is mounted with more pc stand offs then remount the pi on top. My hard drives are stacked on top of each other each on a lexan square, then the hub then my pi with a square on top for protection. That will shrink the overall height of my stack at least an inch, plus it will allow for better routing of some of my cables. Makes for a neater tighter package.
After finally doing some checking turns out the mounting holes are not in the same locations. They are off just enough not to fit in my previously stated configuration.
repulse
Fri Aug 15, 2014 9:48 pm
Sounds like a cool installation !
Maybe you can post a photo, i'm interessted about it :)
EDIT : Max draw on each port of 1.2A ans max overall draw of 2.5A on all port - for "naked" hub
