congenialoki
Wired Ethernet
Sun Aug 10, 2014 10:43 am
Hi to all, have changed a wireless ethernet connection to a hard wired one to overcome the issue of the connection continously dropping, this is now fine. However have run a download speed test on the pi and only get 3mbps, I have a broadband router that delivers in the region of 20/25 mbps to a wireless laptop. Any ideas whats happening to the difference?
Still a very mature newbie!!
Re: Wired Ethernet
Sun Aug 10, 2014 10:45 am
congenialoki wrote:Hi to all, have changed a wireless ethernet connection to a hard wired one to overcome the issue of the connection continously dropping, this is now fine. However have run a download speed test on the pi and only get 3mbps, I have a broadband router that delivers in the region of 20/25 mbps to a wireless laptop. Any ideas whats happening to the difference?
How are you measuring the speeds ??
RPi 4B 4GB (SSD Boot)..
congenialoki
Re: Wired Ethernet
Sun Aug 10, 2014 5:55 pm
With the terminal command, wget -O /dev/null http://speedtest.wdc01.softlayer.com/do ... test10.zip
Have just tried it again and get a speed of 4.8mbps
Thanks for reply.
drgeoff
Re: Wired Ethernet
Sun Aug 10, 2014 6:02 pm
congenialoki wrote:With the terminal command, wget -O /dev/null http://speedtest.wdc01.softlayer.com/do ... test10.zip
Thanks for reply.
You are aware that wget reports speeds in Bs per second? That is bytes not bits.
Re: Wired Ethernet
Sun Aug 10, 2014 6:07 pm
A better test would be to compare how long it takes each computer to download a specific file, rather than comparing bit/byte rates.
