64GB Micro SDXC Class 10 U1 - Compatibility with RPi B+
Posted: Mon Aug 04, 2014 2:07 pm
by kippy
Hi
Can anyone advice whether a 64GB Micro SDXC Class 10 U1 is compatible with RPi B+. I have tried formatting the SDXC card with the SDformatter as well as the EaseUS Partition Master 10.0 but in vain.
The image that I am looking to copy is over 34GB.
Thank you.
Kippy
Re: 64GB Micro SDXC Class 10 U1 - Compatibility with RPi B+
Posted: Mon Aug 04, 2014 2:14 pm
by Joe Schmoe
kippy wrote:Hi
Thank you.
Kippy
What (specifically) have you tried/attempted?
What error messages did you get?
Posted: Mon Aug 04, 2014 2:17 pm
by hansotten
kippy wrote:Hi
Thank you.
Kippy
It could be the card was formatted as eFAT by the utilities you used, because of the large size. Afaik the RPi only knows about fat and fat32.
Can you try formatting as fat32?
Posted: Mon Aug 04, 2014 2:25 pm
by kippy
Hi
I have tried formatting the sdxc from the default exFat to a Fat 32.
Copied the NOOBS.
Tried to boot.
The RPI B+ doesn't seem to recognize the OS.
Note: I am able to boot with the original 8 GB card that came with the RPI with NOOBS.
Thank you.
Posted: Mon Aug 04, 2014 2:31 pm
by RaTTuS
can you try the latest raspbian image downloaded from here ^
Posted: Mon Aug 04, 2014 2:32 pm
by hansotten
kippy wrote:Hi
Copied the NOOBS.
Tried to boot.
Thank you.
How did you copy Noobs? With the Win32DiskImager?
Posted: Mon Aug 04, 2014 3:12 pm
by kippy
@Hansotten - the SDXC was formatted as FAT32.
@RaTTus - Previously, I used the Offline and network install. I am attempting to download the image again and giving it a go with the
Win32Diskimager.
WiIll update on the progress shortly.
Thank you
Posted: Mon Aug 04, 2014 3:29 pm
by kippy
Hi
The image was downloaded from
http://downloads.raspberrypi.org/raspbian_latest
Used Win32Diskimager to copy the image across.
But the RPi doesn't recognize the Raspbian and does not boot-up.
Thank you
Posted: Mon Aug 04, 2014 4:03 pm
by AndrewS
