Patschi
Contact: ICQ Website
XMBC on already installed Debian OS?
Wed Jun 13, 2012 11:24 pm
I've a RPi since 2 days and I saw on youtube a video with the XMBC center. So I wanted to install it too, but I don't know how to do this.
I have found the homepage of the creator of XMBC for Raspberry Pi, but it seems that I have to reinstall my complete debian system. Is it possible to install XMBC without reinstalling the whole system?
Thanks!
My german homepage: http://pkern.at (Ofcourse Raspberry Pi articles too :D)
graemewham
Re: XMBC on already installed Debian OS?
Fri Jun 15, 2012 6:18 am
hi
i have done this and it was not to hard
this is what i did
do first boot with debian
then re image the sd card with the xbmc image don't delete anything just copy the new image over
and then run as normal
you will not have to do anything it will take a few moments for everything to be installed
hope this helps
Patschi
Fri Jun 15, 2012 6:52 am
Also I should download the XMBC image file and copy all with "dd" over my debian system?
Then reboot and it should work?
Thansk for your answer :)
graemewham
Fri Jun 15, 2012 11:41 pm
http://download.raspbmc.com/downloads/b ... ing.img.gz
this is the image i used just download and copy over top of your existing debian image
Patschi
Sun Jun 17, 2012 8:45 pm
I tried it 2 hours before and it works well. But XMBC overwrites the standard desktop and changes the terminal :(
texy
Sun Jun 17, 2012 9:18 pm
graemewham wrote:http://download.raspbmc.com/downloads/b ... ing.img.gz
...exactly - this is not what the OP is asking for. He wants to be able to use an existing Debian image and then install Xbox, but still keep the Debian OS.
Texy
Drew
Sun Jun 17, 2012 11:46 pm
'apt-get' may find a suitable installer.
try
sudo apt-get install xbmc
in the LX Terminal application (under accessories IIRC).
I have no idea if there is a currently available version in the repositories that it uses but it will ask you to confirm if it can find one.
sjfaustino
Mon Jun 18, 2012 7:20 pm
Drew wrote:'apt-get' may find a suitable installer.
try
It appears it's not yet available :(
pi@raspberrypi ~ $ sudo apt-get install xbmc
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
xbmc : Depends: xbmc-bin (>= 2:11.0~git20120510.82388d5-1) but it is not installable
Depends: xbmc-bin (< 2:11.0~git20120510.82388d5-1.1~) but it is not installable
Recommends: python-qt3 but it is not installable
E: Unable to correct problems, you have held broken packages.
mustek
Mon Jun 18, 2012 11:25 pm
Hi.
I have the same problem.
I want to install the XBMC on Debian Wheezy Raspberry Pi minimal image but
raulwberg
Tue Jun 19, 2012 11:25 pm
I would also like to install XBMC in debian wheezy on the R-Pi.
But there are a few dependencies which I can' t seem to satisfy.
here is what I get when I try to install XBMC using aptitude
xbmc : Depends: xbmc-bin (>= 2:11.0~git20120510.82388d5-1) which is a virtual package.
Depends: xbmc-bin (< 2:11.0~git20120510.82388d5-1.1~) which is a virtual package.
any help on this would be greatly appreciated
Cheers
whippy
Wed Jun 27, 2012 10:36 pm
Hi I am also having the same dependancy issue trying to install xbmc on existing wheezy image. would be a real pain to have to use xbmc one and setup my image from scratch. There must be an easier way.
Paul Webster
Contact: Twitter
Thu Jun 28, 2012 5:59 am
XBMC on ARM is not yet in the official Debian respoitory.
You could try copying the binaries and .xbmc directories from a Raspbmc or Openelec installation - however, this is quite error prone.
There is a post on the Raspbmc forum about getting the XBMC nightly build from a location that has an ARM build ... you could try that.
Drew
Thu Jun 28, 2012 12:10 pm
whippy wrote:Hi I am also having the same dependancy issue trying to install xbmc on existing wheezy image. would be a real pain to have to use xbmc one and setup my image from scratch. There must be an easier way.
The easiest way is buy another SD card & use that with Raspbmc (or OpenElec), however if you have more time than money it is possible to take a copy of the current SD card. You basically use 'dd' to copy the entire card. Then you can install Raspbmc, set it up and then take a copy of that with dd too.
Restoring a card can take 30 mins or so, much quicker than a reinstall, update & manual setup.
spchong
Sat Jun 30, 2012 2:40 am
By the way, is the media centre XBMC or XMBC? Both seem to be acceptable to the folks here.. Lol
Drew
Sat Jun 30, 2012 2:53 am
spchong wrote:By the way, is the media centre XBMC or XMBC? Both seem to be acceptable to the folks here.. Lol
XBMC = XBoxMediaCenter
XMBC feels nicer inside my head for some reason. It has infected my ability to search for the correct term :)
itsonlyme
Sat Jun 30, 2012 7:53 am
Same here. We both must have a dose of Raspberry Fever!!
karthikeyan_sw
Tue Jul 03, 2012 4:18 pm
here are the steps to install xbmc on existing debian arm
1. add deb ftp://ftp.deb-multimedia.org squeeze main non-free to /etc/apt/sources.list
2. execute apt-get update, you might see some error, ignore them as of now
3. execute apt-get install deb-multimedia-keyring
4. now its time to add GPG key, download the gpg key package from wget http://www.deb-multimedia.org/pool/main ... -4_all.deb
5. install the downloaded package dpkg -i debian-multimedia-keyring_2010.12.26-4_all.deb
6. again do the apt-get update
7. now install the xbmc apt-get install xbmc
referrences:
http://mbignell.com/2012/04/19/getting- ... pberry-pi/
~SwK.
Cellfreak
Thu Jul 05, 2012 12:28 am
Step 4 above, got shortened... Connect as one long line...
main/d/debian-multimedia-keyring/
This is the error I get
root@raspberrypi:~# sudo apt-get install xbmc
xbmc : Depends: xbmc-bin (>= 2:11.0~git20120510.82388d5-1) but it is not going to be installed
Depends: xbmc-bin (< 2:11.0~git20120510.82388d5-1.1~) but it is not going to be installed
Bergi
Thu Jul 05, 2012 6:51 pm
Step 1 is wrong:
deb ftp://ftp.deb-multimedia.org wheezy main non-free
Patschi
Thu Jul 05, 2012 7:56 pm
Are you sure that it is a good idea, installing software which is compiled for wheezy on Squeeze versions?
carl0s_
Thu Jul 05, 2012 8:28 pm
any updates on this? I really want to install xbmc on wheezy... As squeeze tells me xbmc is not able to start because the screen depth is not 24bit
Bergi
Thu Jul 05, 2012 8:46 pm
It's the only way to install xbmc from deb sources. For now, i guess.
fransschreuder
Sun Jul 08, 2012 2:28 pm
from this forum message: http://www.raspberrypi.org/phpBB3/viewt ... &start=225
I got this information, and an image and it works like a charm!
https://docs.google.com/open?id=0B6NiJG ... FNVR0lGTnM
Along with the steps to install it:
https://docs.google.com/document/d/1IT1 ... 6vhu0/edit
carl0s_
Mon Jul 09, 2012 6:05 am
I'm afraid GDocs links are broken... :/
fransschreuder
Mon Jul 09, 2012 7:13 am
sorry, the links were shortened. here are the good ones:
fransschreuder wrote:from this forum message: http://www.raspberrypi.org/phpBB3/viewt ... &start=225
