http://www.amazon.cm/Logitech-OEM-S150- ... B000XUQ2LI
I've tried everything, the terminal detects them; I've gotten VLC player and set output to USB (many different kinds) and nothing, the .mp3 still doesn't play.
Please help out
Dude I love you. I've had my USB as default through many tutorials set up already but the volume was at 0; I pop open Alsamixer, put it at 100 and now with VLC my speakers are working.fruitoftheloom wrote:The first part of this tutorial shows how to set default audio device via ALSA
http://asliceofraspberrypi.blogspot.co. ... evice.html
all this because RPi doesn't have a visual volume meter hahaPaul Webster wrote:Don't forget to reboot (shutdown and remove power - pause - power on) to verify that the volume setting is retained after restart.
In Raspbian you can add the Speaker Icon to the LXDE Task Barmarat569 wrote:all this because RPi doesn't have a visual volume meter hahaPaul Webster wrote:Don't forget to reboot (shutdown and remove power - pause - power on) to verify that the volume setting is retained after restart.
Well I just got my rpi today thanks!fruitoftheloom wrote:In Raspbian you can add the Speaker Icon to the LXDE Task Barmarat569 wrote:all this because RPi doesn't have a visual volume meter hahaPaul Webster wrote:Don't forget to reboot (shutdown and remove power - pause - power on) to verify that the volume setting is retained after restart.
http://www.linuceum.com/Distros/osDesktopConfigLXDE.php
Not really - I did not know you are using a UI. My music streaming RPis tend to run "headless" so having things start up in the right state is important to me.marat569 wrote:all this because RPi doesn't have a visual volume meter hahaPaul Webster wrote:Don't forget to reboot (shutdown and remove power - pause - power on) to verify that the volume setting is retained after restart.
