udara
How to Connect MS SQL Server From RPi
Sat Jul 26, 2014 5:27 am
I have a computer with MS SQL Server database in my net work and I need to connect it and read data and modify data from RPi. I'm using 2014-06-20-wheezy-raspbian in my RPi and already updated. I install pyodbc using
sudo apt-get install unixodbc python-pyodbc
I'm using following code,
import pyodbc
connectionDbServer = pyodbc.connect(driver='{SQL Server}', server='***.***.***.***', database='***', uid='***', pwd='***')
cursorDbServer = connectionDbServer.cursor()
cursorDbServer.execute("xxxxxxx")
cursorDbServerRows = cursorDbServer.fetchall()
print cursorDbServerRows
connectionDbServer.close()
When I execute this code it gives me error saying
pyodbc.Error: ('IM002', '[IM002] [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified (0) (SQLDriverConnectW)')
Code is working fine in windows and it retrieve data from DB.
Is there some thing else I need to do in here to make this work please help.
Thanks.
udara
Re: How to Connect MS SQL Server From RPi
Sun Jul 27, 2014 5:24 am
I also tried to connect using pymssql it seems like it connect to database but it returns a empty data list "[]"
pymssql 1.0.2 and I cannot update this to 2.0 because it requires "setuptools-0.6c9-py2.7.egg" and I cant find it out, I cant figure out the issue please help.
AndrewS
Sun Jul 27, 2014 2:29 pm
I can't offer any personal help, but have you looked through http://www.raspberrypi.org/forums/searc ... ords=mssql ?
udara
Mon Jul 28, 2014 2:54 pm
Thanks.
I tried to create the connection by editing these files,
/etc/odbc.ini
/etc/odbcinst.ini
/etc/freetds/freetds.conf
but it didn't work. I think it is better to use MySQL for database because it can configure very easily.
Thanks.
