slivingston49
Teamviewer on Raspberry Pi? [obsolete]
Thu Jul 24, 2014 5:03 pm
Trying to see if its possible to use Team viewer to remote into a few different computers. Is it possible?
http://www.teamviewer.com/en/download/linux.aspx
A1i2T3R
Re: Teamviewer on Raspberry Pi?
Thu Jul 24, 2014 5:22 pm
You should be able to use it on the pi, however there might be a little config Also im not sure the pi could handle such bloated software. But you can try. If i were you i would stick to ssh and ftp.
Enthusiastic pi user, with a hoby for modding everyday objects and using the pi as the brain!
DirkS
Thu Jul 24, 2014 5:45 pm
A1i2T3R wrote:You should be able to use it on the pi, however there might be a little config Also im not sure the pi could handle such bloated software. But you can try. If i were you i would stick to ssh and ftp.
Are you sure? I thought teamviewer was only available with intel linux platforms which is not compatible with arm-linux.
Gr.
Dirk.
mikerr
Thu Jul 24, 2014 5:54 pm
Downloaded deb v9.0.30203 32-Bit / 64-Bit Multiarch from
 sudo dpkg -i teamviewer_linux.deb
dpkg: error processing teamviewer_linux.deb (--install):
 package architecture (i386) does not match system (armhf)
Thu Jul 24, 2014 5:55 pm
http://www.raspberrypi.org/forums/searc ... teamviewer
TeamViewer is a closed source 32/64 x86 application, plenty of alternatives
Thinking outside the box is better than burying your head in the sand...
A1i2T3R
Fri Jul 25, 2014 9:05 am
Gr.
Dirk.
You probably know more than me,
hhoanganh
Sat Jul 26, 2014 12:38 am
i'm using TightVNC, it's good
danielktdoranie
Tue Jul 21, 2020 2:38 pm
Guide here. Caveat Emptor! I believe this only works for 32-bit Raspberry Pi OS and not currently 64-Bit Raspberry Pi OS. Read the entire how-to before you attempt an install, it's not super clean... pretty dirty in fact... I will install on a 32-bit install of Raspberry Pi OS and report back at later date.
There's a thread here about making it work with 64-bit but someone has reported it messed up their Apt. I would make an image of your SD card before you attempt this, this way if it completely borks your Apt you can go back to a saved state.
I will install both on 32-bit and 64-bit and report back,
mahjongg
Tue Jul 21, 2020 3:58 pm
You are replaying to an ancient post, in six years various different versions of the OS were released!
so this thread and HOWTO is now simply obsolete!
posting problems to the new 64-bit Alpha feedback thread is excellent, but you take the risk that your experience was based on obsolete experience, of how to do the things you are explaining about, its possible that there are now new ways to do something..
bonzadog
Tue Jul 21, 2020 4:02 pm
I see a LOT of Teamviewer users complaining about being incorrectly classified as a commercial user. When this happens one needs to fill out a form or each ID and wait for a while until the IDs get unblocked.
So if you are on a local WLAN then use VHC to connect - that works very well.
mooblie
Re: Teamviewer on Raspberry Pi? [obsolete]
Tue Jul 21, 2020 7:11 pm
VNC, not VHC. (just for info.) :x
Return to “Beginners”
