tm48
No Module Named Tkinter
Wed Jul 23, 2014 12:26 pm
I am new to the raspberry Pi and Python but I have exprience programming. I am getting errors running the following program:
from tkinter import *
root = tk.Tk()
canvas = tkinter.Canvas(root)
canvas.grid(row = 0, column = 0)
photo = tkinter.PhotoImage(file = './blah.jpg')
canvas.create_image(0,0, image=photo)
root.mainloop()
But I get the following error:
File "/home/pi/tkinterpy1.py", line 1, in <module>
ImportError: No module named tkinter
How can I fix this? Is it possible to delete and re-install tkinter on the pi? I am using Debian.
AndyD
Re: No Module Named Tkinter
Wed Jul 23, 2014 12:37 pm
You need to install python-tk
sudo apt-get install python-tk
gkreidl
Wed Jul 23, 2014 4:53 pm
import Tkinter (capital T) in Python 2.7 ..., tkinter in Python3
Which version of Python are you using?
It should be installed by default.
Minimal Kiosk Browser (kweb)
AndyD
Wed Jul 23, 2014 10:43 pm
gkreidl wrote:It should be installed by default.
Are yes ... sorry my mistake!
tm48
Thu Jul 31, 2014 8:19 am
gkreidl wrote: Which version of Python are you using?
I am using Python 3.2.3. So, I just ran the same program I had before and got a different error this time:
File "/home/pi/tkinterpy1.py", line 3, in <module>
NameError: name 'tkinter' is not defined
gkreidl
Thu Jul 31, 2014 10:13 am
replace
to
import tkinter
Then your code should work.
tm48
Thu Jul 31, 2014 10:36 am
gkreidl wrote:replace
to
import tkinter
I replaced it. But now I am getting the following error:
File "/home/pi/tkinterpy1.py", line 2, in <module>
root = Tk()
NameError: name 'Tk' is not defined
gkreidl
Thu Jul 31, 2014 10:43 am
root = tkinter.Tk()
using "from module import *"
imports everything into the local name space. You have to decide what you are doing. Mixing it will not work.
tm48
Thu Jul 31, 2014 12:52 pm
photo = tkinter.PhotoImage(file = '/home/pi/blah.jpg')
This line of code gave me the following error:
File "/home/pi/tkinterpy1.py", line 5, in <module>
File "/usr/lib/python3.2/tkinter/__init__.py", line 3255, in __init__
Image.__init__(self, 'photo', name, cnf, master, **kw)
File "/usr/lib/python3.2/tkinter/__init__.py", line 3211, in __init__
self.tk.call(('image', 'create', imgtype, name,) + options)
_tkinter.TclError: couldn't recognize data in image file "/home/pi/blah.jpg"
Does this not read JPGs? Should I save my image as a PNG or another file type instead?
DirkS
Thu Jul 31, 2014 2:00 pm
According to the docs https://docs.python.org/3.0/library/tki ... photoimage:
PhotoImage can be used for GIF and PPM/PGM color bitmaps.
