jimfowler82
Wireless USB keyboard & Mouse
Tue Jun 12, 2012 12:49 pm
Hi guys,
Hope this hasnt been asked before but im having a few problems with my USB wireless setup on the PI.
I got my RaspberryPI this morning and amazed at how small it is! for some reason i know it was said to be credit card size but wow its so small :) Anyway...
What it is i have an Microsoft wireless keyboard and mouse set-up which i use on my everyday set-up, I thought that i might be able to just plug and play with the Raspberry PI with this set-up, BUT sadly i seem to be getting typing errors with it like keyboard lag and the enter keeps pressing, It picks it up as what it is i see the driver load on bootup.
Basicly is this a known problem or should i try something else? Or should i just go and buy a cheapy usb keyboard/mouse setup :) ?
Replies very much appreciated.
Jim
jimfowler82
Re: Wireless USB keyboard & Mouse
Tue Jun 12, 2012 12:55 pm
Hi guys just did a google search which i should have done first! I see my keyboard is very close in model to a microsoft wireless 2000 which has problems with sticky keys mine is a 3000 and has same problem :(
Will look at a list of working keyboards and grab one later :)
h9k
Tue Jun 12, 2012 2:46 pm
Can I add to this that I went out and bough (on day of pi arrival) a microsoft wireless keyboard and mouse, model Desktop 800 and it had exactly tha same laggyness and repeat char entry problem.
I would suggest avoiding this combo
geep999
Tue Jun 12, 2012 3:15 pm
I think it's a Debian problem. I don't see the problem with ArchLinux.
See:http://tinyurl.com/cgb2new
Cheers,
Peter
monojohnny
Thu Jun 21, 2012 11:52 am
Just for reference:
I also saw this issue (having to press the key twice for the typed character to show up; also a 'sticking' issue - where the character 'auto-repeats' even though nothing is pressed) on a Microsoft Wireless Keyboard/Mouse Combo.
This was on the Debian build - I will try the other images to see what result I get.
I don't have the exact version /model numbers of the keyboard/mouse with me right now, but I'll follow up once I get hold of the details.
sduskin
Thu Jun 21, 2012 1:35 pm
I use a cheap Logitech $25 US from Walmart. Absolutely no problems with any of the 4 distros I have tried. It is a keyboard and mouse and uses a single nano receiver.
thunderbyte
Tue Sep 25, 2012 1:33 am
I have the same problem. In dmesg I see lots of message like this:
[ 3481.566687] usb 1-1.2: reset full-speed USB device number 4 using dwc_otg
[ 3482.856839] usb 1-1.2: reset full-speed USB device number 4 using dwc_otg
[ 3484.506918] usb 1-1.2: reset full-speed USB device number 4 using dwc_otg
[ 3484.726803] usb 1-1.2: reset full-speed USB device number 4 using dwc_otg
[ 3485.956851] usb 1-1.2: reset full-speed USB device number 4 using dwc_otg
[ 3486.236883] usb 1-1.2: reset full-speed USB device number 4 using dwc_otg
[ 3486.426898] usb 1-1.2: reset full-speed USB device number 4 using dwc_otg
[ 3487.936974] usb 1-1.2: reset full-speed USB device number 4 using dwc_otg
[ 3488.206991] usb 1-1.2: reset full-speed USB device number 4 using dwc_otg
lsusb:
Bus 001 Device 004: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
rew
Tue Sep 25, 2012 1:04 pm
It could be that your device requires more power than the rasbperry pi (version 1) can deliver. So: Can you power your keyboard through a hub?
If you're feeling adventurous, you can short the two fuses near the USB connector on the bottom of the board.
Check out our raspberry pi addons: https://www.bitwizard.nl/shop/
