pegasis
weather app
Tue Jul 15, 2014 6:22 pm
can someone tell me the apt command to install weather app on RPI?
as in command: weather ICT (which shows the weather in wichita)
ukscone
Re: weather app
Tue Jul 15, 2014 6:58 pm
don't know an apt-able weather app but there is a nice understandable python one on brainwagon's blog http://brainwagon.org/2014/07/08/some-e ... forecasts/
pegasis
Re: weather app
Tue Jul 15, 2014 7:20 pm
this one:
sudo apt-get install aweather
sesm to work in wheezy, but not recognized in debain 7??
pegasis
Re: weather app
Sat Mar 07, 2015 2:38 pm
when I run the weather ICT command
I get an error of can't find stations data file
How can i fix this?
Re: weather app
Sat Mar 07, 2015 3:11 pm
pegasis wrote:when I run the weather ICT command
How can i fix this?
""aweather
Advanced Weather Monitoring Program
AWeather is an advanced weather program which is designed to be used by weather enthusiasts. AWeather is not a weather dockapp that simply displays a pre-computed forecast. It is designed to be an easy-to-use program that integrates a variety of weather data in a simple unified interface. AWeather currently supports radar and weather alerts from the United State National Weather Service.""
http://pileus.org/aweather/manual
Retired disgracefully.....
......to a more gentile life !
ioha
Re: weather app
Sat Mar 07, 2015 3:35 pm
you can also have a look here: http://www.maketecheasier.com/access-we ... mand-line/ (but only U.S.A. ...)
or here: https://github.com/subrosa2/weatherman using forecast.io (not very good current temperature, but good forecast)
or here: http://openweathermap-requests.readthed ... en/latest/ using openweathermap.org (good current temperature, but not very good forecasts)
Raspberry Pi 1 Model B+ (since 2014-08-10): Raspbian jessie / Debian 8.1
Raspberry Pi 2 Model B (since 2015-03-10): OpenELEC 5.0.8
