rapidograf
ssh edithor for Python
Thu Jun 12, 2014 11:32 am
sorry for easy question for profi
task. :
1. need connect Raspi and home compyter by local wifi net. (no question)
questions
2. need Python edithor installed on windows side
3. edit programms on the Raspi side , and run programm on Rasbi by remote from windows ?
what you can adwice ?
or use Pythoon editor into Raspi by remote from windows .
bigest and hugest same as tiny and micro
DavidMS
Re: ssh edithor for Python
Thu Jun 12, 2014 11:37 am
Is there a reason you cannot use a Virtual connections [VCN] eg with an application like tightvnc ?
http://meanderingpi.wordpress.com/
11 Raspberry Pi's and counting....
klricks
Thu Jun 12, 2014 12:10 pm
Install xrdp on the RPi and use the built in remote desktop (RDP) in Windows.
sudo apt-get install xrdp
rapidograf
Thu Jun 12, 2014 12:26 pm
klricks wrote:Install xrdp on the RPi and use the built in remote desktop (RDP) in Windows.
thank you ! can you advice to me suitable edithor for Pythone ? (for this case)
klricks
Thu Jun 12, 2014 12:39 pm
IDLE and IDLE3 are already installed with start icons on the desktop (Raspbian OS).
rapidograf
Sun Jun 22, 2014 5:15 pm
i tryed but i have WinXP home edition , have you any advice how use RDP on this OS ? :?: :cry:
DirkS
Sun Jun 22, 2014 5:35 pm
The RDP client (aka Terminal Services client) should be available on XP home. If you cannot find it in the menu then try to use Start / run and enter 'mstsc' as the command (without the quotes).
If you're sure it's not on your WinXP machine you can download it from the MS site: http://www.microsoft.com/en-gb/download ... px?id=7208
HTH
Dirk.
klricks
Sun Jun 22, 2014 5:42 pm
Or download one of the many 3rd party RDP clients.
rapidograf
Sun Jun 22, 2014 6:21 pm
klricks wrote:Or download one of the many 3rd party RDP clients.
How about UltraVCN ? can i use it for use remote display ?
rapidograf
Sun Jun 22, 2014 6:23 pm
HTH
Dirk.
Yuo are genius !!! mstsc it works ! i will try to connect again .... may be i connect it between together
DirkS
Sun Jun 22, 2014 7:25 pm
Yuo are genius
I know ;)
rapidograf
Mon Jun 23, 2014 11:49 am
DirkS wrote:
Yuo are genius
I know ;)
after dancing with drums and wires i connect Raspi and PC by remote screen.
(but i did not use keybord because i'm was dancing and %&$#$%ing)
Mr. DirkS may be you are invented by your grnius brsin how , when Raspi boot , automatically run following string ? ;) this string so long and i have always mistake when input it (pray)
"vncserver :1 -geometry 1024×600 -depth 16 -pixelformat rgb565"
DirkS
Mon Jun 23, 2014 12:15 pm
Adding the line to /etc/rc.local (*before* the line with 'exit 0' and without the quotes) should work AFAIK.
You'll need root rights to edit this file so you could use:
sudo nano /etc/rc.local
Another way of doing it: http://www.raspberrypi.org/documentatio ... /README.md
HTH
Dirk.
rapidograf
Mon Jun 23, 2014 2:08 pm
DirkS wrote: Dirk.
it is off topic.
mr Dirk i'm again dancing with drum - install Apache but without success.
1) sudo apt-get install apache2
2) do "sudo service apache2 restart" after that Raspi return string "apache2: unrecognized service"
3) i input into PC brouser IP addraess (192.168.1.7) of Raspi but brouser show "connection was failed"
how correctly install Apache ???
DirkS
Mon Jun 23, 2014 2:12 pm
rapidograf wrote:
DirkS wrote: Dirk.
it is off topic.
It's off-topic *and* you just asked the same question elsewhere on the forum...
I have never installed Apache on a Pi before, so I can't help you there.
Try googling for 'raspberry pi install apache' and you'll find loads of hits, including this one: http://www.raspberrypi.org/documentatio ... /apache.md
Gr.
Dirk.
rapidograf
Mon Jun 23, 2014 4:38 pm
DirkS wrote:Adding the line to /etc/rc.local (*before* the line with 'exit 0' and without the quotes) should work AFAIK.
HTH
Dirk.
i did it but not working ...... i add string with command , but vncserver not run.
maybe before string add "sudo" ? or add somethoing else :(
Return to “Beginners”
