JustCurious
Usb-out power?
Mon Jun 09, 2014 12:05 pm
Can the Pi deliver 500mA over USB?
FLYFISH TECHNOLOGIES
Re: Usb-out power?
Mon Jun 09, 2014 12:07 pm
JustCurious wrote:Can the Pi deliver 500mA over USB?
The RasPi is designed to (reliably) supply 100mA over each USB.
Best wishes, Ivan Zilic.
Running out of GPIO pins and/or need to read analog values?
Solution: http://www.flyfish-tech.com/FF32
JustCurious
Re: Usb-out power?
Mon Jun 09, 2014 12:11 pm
So, if I need 500mA, I have to insert a powered USB hub?
ghans
Re: Usb-out power?
Mon Jun 09, 2014 12:15 pm
Yes.
ghans
Re: Usb-out power?
Mon Jun 09, 2014 12:21 pm
JustCurious wrote:So, if I need 500mA, I have to insert a powered USB hub?
Yes, you need to overcome this limitation somehow...
Powered USB hub is one solution, another one is described here:
http://www.raspberrypi.org/forums/viewt ... 93#p496993
