7ewis
How can I connect the Pi to my TV?
Sun Jun 08, 2014 9:52 am
Hi guys, I'm not exactly a 'beginner', but I'm just clueless with older cables.
So, I have an old Goodman's TV (GTV30WLCD) and would somehow like to connect my Pi to it.
It has the yellow, white, red and SCART on the side, and I believe I used to connect a PS3 to it using a scart adapter to RGB for some reason... So I have one of those. I also have a lot of cables that have red, yellow and white one side and just black on the other, but if I am correct, I think I need one that fits into the yellow RCA port? This black cable doesn't.
I will probably have the correct cable/adapter lying around somewhere but I just need to know what to look for!
Raspberry Pi - Model B (512MB)
Re: How can I connect the Pi to my TV?
Sun Jun 08, 2014 10:03 am
Retired disgracefully.....
klricks
Sun Jun 08, 2014 12:38 pm
If you want to send audio from RPi to the TV then you will also need a cable like this:
http://www.ebay.com/itm/2x-6FT-3-5mm-1- ... 1e8613d4e6
FTrevorGowen
Sun Jun 08, 2014 12:49 pm
FWIW this is what I've used:
http://www.cpmspectrepi.webspace.virgin ... T.29_Cable
(NB: The SCART adapter needs to be {or switched to be} an INPUT device)
If you're planning to use the NOOBS installer, composite video is "somewhat tricky" so you may find this link useful:
http://www.cpmspectrepi.webspace.virgin ... ellow.html
Trev.
