skuydi
Raspi and Tinkerforge
Thu May 29, 2014 10:44 am
Hello to all,
I'm a beginner with the raspi, python and tinkerforge.
I would like to start a script a the boot of the raspi
I add my script to the /etc/rc.local.
On boot, the script is starting but with error
EOFErro : EOF when reading a line
Exception in thread Disconnect-Prober (most likely raised durint interpreter shutdown):
File "/usr/lib/python2.7/threading.py", line 552 in __bootstrap_inner
File "/usr/lib/python2.7/threading.py", line 505, run
File "/home/pit/tinkerforge/ip_connection.py", line 8016 in disconnect_probe_loop
File "/usr/lib/python2.7/Quee.py, line 174, in get
<type 'exception.Type.Error'>: 'NoneType' object is not callable.
If I try to start the script manual after the boot, the script run.
If I try with a script "Hello World", it is OK
I need help please !
DeeJay
Re: Raspi and Tinkerforge
Thu May 29, 2014 12:58 pm
Can I politely suggest that you are more likely to get informed advice if you state which Operating System you are running on your RPi, and if you post a copy of the script that you are invoking from /etc/rc.local
Trying to understand what you have already posted, I notice this line -
Have you created a new user for your system, named pit? Or could that be a typing error that might be causing your problem?
