grasmanek94
Which OS to use for programming GPIO pins?
Fri May 23, 2014 11:17 pm
Well, I have looked at the Wiki page which lists about 46 different distributions to install on the PI (I have a B) that it's plain confusing. (Even the sorting doesn't really help anything)
I need an OS which allows me to just place a program onto the SD card, and let the PI run it.
So a simple OS which does this:
Startup,
Initialize LAN
Load very small program (something like arduino sketch)
Maybe even output some text to the screen...
Execute till power-off
And that's it..
All the OS'es I compared are for full fledged systems to browse the internet, watch movies, listen to music, all too hardcore for what I want to do.
Is the an "arduino OS" for raspberry pi or something like that?
ShiftPlusOne
Re: Which OS to use for programming GPIO pins?
Sat May 24, 2014 12:22 am
Linux is just fine. Just because Linux 'can' be used for all of the other things you've mentioned doesn't mean that you can't use it for very simple things. Linux is used on such a wide variety of devices for this exact reason - it's very flexible. It may take a little bit of learning to create your own distro which suits you though.
Of course you may wish to take a look at RISC OS, but I'm clueless there.
Sat May 24, 2014 7:49 am
grasmanek94 wrote:I need an OS which allows me to just place a program onto the SD card, and let the PI run it.
Start simple. Use NOOBS/Raspbian.
This is a doctor free zone.
DeeJay
Sat May 24, 2014 8:48 am
Agreeing with @DougieLawson, but with more words... http://www.raspberrypi.org/forums/viewt ... 97#p537024
Sun May 25, 2014 10:40 am
DeeJay wrote:Agreeing with @DougieLawson, but with more words... http://www.raspberrypi.org/forums/viewt ... 97#p537024
+1 for that.
grasmanek94
Sun May 25, 2014 12:59 pm
alright, I installed raspbian wheezy and disabled gui and make root autologon.
It now does nothing except listen for commands on SSH :)
(but the boot-up time is quite long, around 40 seconds)
Also, is there a special C++ cross-compiler for raspbian wheezy to use on Windows? (or do I have revert to cygwin? which sometimes does not output correct binaries / is easy to misconfigure)
