How to connect a PiHUB?
Posted: Thu May 22, 2014 6:40 am
by tanja.sialevri
I just got my PiHUB but there are no instructions on how to use it :(
I need:
  • To connect it to 3 USB devices,
    The USB devices need to be controlled by 1 Rpi,
    That Rpi would (preferably) be powered by the PiHub too.
Could you help me?
Re: How to connect a PiHUB?
Posted: Thu May 22, 2014 8:31 am
by DeeJay
It's just a powered usb hub in an RPi-shaped case.
Hopefully you bought a good quality power adapter as well.
The PiHub needs to have power: Plug the power feed from the power adapter into the PiHub - but leave the power off for now.
The RPi needs to have power: Plug the earmarked RPi power outlet from the PiHub into the microusb power input on the RPi.
The RPi needs to be able to share its usb connection with other devices on the hub: Plug one of the usb connectors on the RPi into the usb-input connector on the PiHub.
The other accessories need to be able to communicate with the RPi: Plug your other accessories into the remaining usb connectors on the PiHub.
Turn on power to the PiHub power adapter.
In pictures - see here - http://youtu.be/gysq2KWwqAU
