reggie4
quick help
Tue May 20, 2014 6:51 pm
Hi all, iv'e been making the open cv librarys for hrs, and iv'e just noticed i'm about to run out of space on my root.
1) can i pause the build
2) what can i quickly do to free up space?
3) can i remove oracle-java7-jdk
I need a quick response before my build crashes
Re: quick help
Tue May 20, 2014 7:00 pm
Lots of Makefile based builds will carry on from where they left off (as long as nothing gets updated in the source or build directories).
reggie4
Re: quick help
Tue May 20, 2014 7:08 pm
Hi Dougie,
Iv'e done:
1)
apt-get clean
2)
dpkg-query -W -f='${Installed-Size;10}\t${Package}\n' | sort -k1,1n # sort -k1,1n	List all packages by installed size (KBytes) on deb distros
3)
sudo apt-get remove wolfram-engine
4) and remove oracle-java7-jdk looks big, but not sure if i need it.
5) is there any big files/ programs i can remove? Iv'e removed scratch.
How big is opencv after the make? Can i fit it onto a 4Gb Card?
Re: quick help
Tue May 20, 2014 7:13 pm
Is this a NOOBS card? Or is it a Raspbian image?
Because undoing NOOBS gets 1.2GB back. But you'll need somewhere to write the images of /dev/sda5 and /dev/sda6 while you do that.
The other option is a new 8GB (or bigger) SDCard.
reggie4
Re: quick help
Tue May 20, 2014 7:24 pm
It,s Raspbian.
I should have checked space needed before trying to install!
Is there a clean/easy way to stop and delete the make + all the other stuff i installed for opencv? Other than writing the last backup image?
Thanks again,
Dougie.
reggie4
Re: quick help
Tue May 20, 2014 7:29 pm
1) If i let the make fail (run out of space)
2) backup the SD card image to my laptop
3)write that image to a new get an 8GB card
Can i continue the make on the new card?
Re: quick help
Tue May 20, 2014 7:31 pm
Can you run
df
and
sudo fdisk -l /dev/mmcblk0
Re: quick help
Tue May 20, 2014 7:33 pm
If you can expand the file system on the new card then it'll all carry on from where you left off.
reggie4
Re: quick help
Tue May 20, 2014 7:43 pm
df:
Filesystem 1K-blocks Used Available Use% Mounted on
rootfs 3744520 3667448 0 100% /
/dev/root 3744520 3667448 0 100% /
devtmpfs 183312 0 183312 0% /dev
tmpfs 38316 244 38072 1% /run
tmpfs 5120 0 5120 0% /run/lock
tmpfs 76620 0 76620 0% /run/shm
/dev/mmcblk0p1 57288 19128 38160 34% /boot
https://dav.box.com/dav 10485756 0 10485756 0% /home/pi/box
sudo fdisk -l /dev/mmcblk0:
Disk /dev/mmcblk0: 4026 MB, 4026531840 bytes
4 heads, 16 sectors/track, 122880 cylinders, total 7864320 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000981cb
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 8192 122879 57344 c W95 FAT32 (LBA)
/dev/mmcblk0p2 122880 7864319 3870720 83 Linux
Re: quick help
Tue May 20, 2014 8:40 pm
Best bet is to dd that to an 8GB card.
You'll need a USB SDCard reader
sudo dd if=/dev/mmcblk0 of=/dev/sda bs=30M
When it's done you can boot the new card and use sudo raspi-config to expand the rootfs to use the whole card. That'll get a bucket of free space for you.
