Relay board
Posted: Tue Apr 29, 2014 9:52 am
by meddyliol
I am thinking about getting one of these from ebay: http://www.ebay.co.uk/itm/New-5V-8-Chan ... 8254400%26
It seems to be a good buy but will the Pi be able to switch the relays as they need 5V? I seem to remember reading that the Pi will only supply 3.3V.
Cheers
Brian
Re: Relay board
Posted: Tue Apr 29, 2014 10:11 am
by joan
The board needs 5V to energise the relay coils. You can supply that from the Pi's 5V rail.
Usually the logic circuitry can work at a lower level. See if you can find a listing which mentions compatibility with a 3V3 micro. I bought one which mentioned MSP (a 3V3 micro). I'm not sure if any of the micros mentioned in that listing are definitely 3V3.
If you can't find one just buy the one you list. If you are lucky it will just work, if not you'll need to spend another couple of quid on additional components.
My board https://www.youtube.com/watch?v=RDrZDYGRj90
Re: Relay board
Posted: Tue Apr 29, 2014 10:16 am
by meddyliol
Thank you for that. You say you bought one that works on 3.3V. Could you give me a link to that one?
Brian
Re: Relay board
Posted: Tue Apr 29, 2014 10:17 am
by GTR2Fan
The total energising current to switch all 8 relays could be up to 160mA according to the specs. Your Pi might not be happy supplying this amount of current from the 5V pin on the GPIO port if you're powering anything off the USB ports at the same time.
Re: Relay board
Posted: Tue Apr 29, 2014 10:23 am
by joan
I bought from http://www.ebay.co.uk/itm/400514325341
Caution: The 8ch relay I received was not identical to the photo. Mine has different silk screening without the Keyes logo.
Re: Relay board
Posted: Tue Apr 29, 2014 10:28 am
by joan
GTR2Fan wrote:The total energising current to switch all 8 relays could be up to 160mA according to the specs. Your Pi might not be happy supplying this amount of current from the 5V pin on the GPIO port if you're powering anything off the USB ports at the same time.
Good point.
The one I bought takes 70mA to energise a coil. If I try to switch them all on the Pi crashes.
http://www.raspberrypi.org/forums/viewt ... 59#p394659
Re: Relay board
Posted: Tue Apr 29, 2014 10:34 am
by meddyliol
Thanks to the both of you for valuable advise. I will get one of those relay boards but build a buffer circuit at the 3v3 outputs.
Re: Relay board
Posted: Tue Apr 29, 2014 3:16 pm
by Tarcas
meddyliol wrote:Thanks to the both of you for valuable advise. I will get one of those relay boards but build a buffer circuit at the 3v3 outputs.
No need for the buffer circuit. Just wire the VCC to 3.3 and JD-VCC to 5v.
This video explains more.
