electrojim
sound/microphone +usb ports
Mon Apr 21, 2014 11:16 am
Hi guys,
I need a recommendations for a microphone a speaker and a usb port extender.
As part of a project I am working on voice home automation I have a script for Google speak /now I have seen a usb microphone on eBay but that then takes my only available usb port I would like to use my audio jack with a speaker any recommendationsor help be much appreciated thanks in advance
Tarcas
Re: sound/microphone +usb ports
Mon Apr 21, 2014 6:17 pm
For a speaker, I picked up one of these for $5 at a local store. Has an onboard amp powered by a battery charged via microUSB (you can leave it plugged into the Pi to keep it charged.) Note the audio cable is only about 4 inches long, so it has to be right on or next to the Pi. It does not have volume control, so you need to use software to turn it down if necessary.
I've done voice control with my Pi also, and I used a microphone built into the cheapest Webcam that Micro Center had several years ago. Sorry I don't know the make or model, but what I'm saying is that almost any USB mic should work, even if it's integrated with something like a webcam. You can't plug a microphone into the audio jack, as that is output only. Your two options are USB (easiest) and an Analog to Digital Converter (harder.)
Richard-TX
Mon Apr 21, 2014 6:33 pm
Check out the Behring 302USB mixer/DAC. It should do eveything you need.
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
FTrevorGowen
Mon Apr 21, 2014 6:44 pm
electrojim wrote:Hi guys,
By "a usb port extender" do you mean a USB hub? (ie. something that will provide you with more USB ports, not something to allow you to use USB over a "long distance")
If so there are a lot of "4-port" hubs available but "you get what you pay for". FWIW, there's a list of what I've "tried and tested" here:
http://www.cpmspectrepi.webspace.virgin ... Dlist.html
I'd recommend getting one that can be powered (when necessary) similar to the Hama or Targus one's therein.
Trev.
