Re: Help!!!!
Posted: Tue Apr 29, 2014 12:38 am
No, no, no.ame wrote:Picture a player-piano with a paper roll with holes in it to play a tune.
A small, affordable computer with free resources to help people learn, make things, and have fun
https://www.raspberrypi.org/forums/
https://www.raspberrypi.org/forums/viewtopic.php?f=91&t=74948
I was thinking baby steps first.Douglas6 wrote:No, no, no.ame wrote:Picture a player-piano with a paper roll with holes in it to play a tune.We want interaction. Picture a MIDI keyboard that plays the umbrellas in a live performance. Or they respond to the sound of music, like an FFT spectrum analyzer. Or perhaps use a Leap Motion device to read hand gestures. Or...heck you probably have your own ideas. The point being that it's easy now to programmatically control the servos with say, Python, in response to just about any input you can think of, it doesn't have to be predetermined. And by 'easy', I mean many frustrating hours of code debugging.
Yes, good point, I got carried away.ame wrote:I was thinking baby steps first.
dadcanyouhelp wrote:Hi All, never heard of Raspberry Pi until about an hour ago, an assistant in Maplin told me a bit,
My daughter is in her last year at uni and is onto her final pieces, so I got one of those "can you help Dad" calls
Katie wants to Automate approx 10-20 cocktail umbrellas just to open and close in a sequence or to be pir/pressure activated,
my initial thought was to use small servo's to operate the umbrellas and have some form of transmitter/receiver set-up but then Katie said about Arduino's so i went off to maplins and hey presto i'm now trying to learn quickly about RP and hopefully get some advice and guidance from forum members PLEASE ??
Cheers
Tim
Tarcas wrote:well... with the right hardware and code, the Pi could do it. So could an Arduino. What are you thinking for hardware? Servos can work with the Pi, but there are probably other options that could work too.dadcanyouhelp wrote:Hi All, never heard of Raspberry Pi until about an hour ago, an assistant in Maplin told me a bit,
Cheers
Tim
Do remember that the Pi's GPIO pins are 3.3v with a max of 16 mA per pin with a max total of 50 mA.
I think at one point, servos and pneumatics were each mentioned. IMO, I think pneumatics would probably be the better choice, but I'm not sure if that's still on the table since servos are all that have been discussed at length.Ravenous wrote:Agreed, I've been watching this thread with curiosity and don't understand how the umbrellas open. Perhaps I'm not a cocktails guy![]()
Initially I thought perhaps one motor could be used with cams or levers to open all of them in one sequence, but if the sequence can change they'll definitely need one "actuator" of some sort each.
This is one Idea, Might workboyoh wrote:Tarcas wrote:well... with the right hardware and code, the Pi could do it. So could an Arduino. What are you thinking for hardware? Servos can work with the Pi, but there are probably other options that could work too.dadcanyouhelp wrote:Hi All, never heard of Raspberry Pi until about an hour ago, an assistant in Maplin told me a bit,
Cheers
Tim
It seems a good project . Opening and closing
Cocktail Umbrellas
Not being a party goer , I have never seen a
Cocktail umbrella. What are the mechanics
Of how the umbrella opens and closes
How are you linking it to the server.
Would small Solenoids do the same job
