Johnbot
Transfer Image To New SD Card
Mon Jun 04, 2012 6:05 pm
Hello. So I recently received my Raspberry Pi, and the only SD card that I had that wasn't currently being used was only 2 gigabytes in size. I used it for several days, and then purchased a 16 gigabyte SD. I tried using the win32diskmanager to pull my old sd card image from the 2 gigabyte card, and then use that image on my 16 gigabyte card... But now my Pi sees the 16 gigabyte card as only being 2 gigabytes large! (I did kind of see that coming, but I was hoping it wouldn't...) Anyways, does anyone know of a way to increase the perceived size of my SD card?
Thanks,
John
stevepdp
Re: Transfer Image To New SD Card
Mon Jun 04, 2012 6:10 pm
This tutorial by Raspberry Pi Tutorials (Liam Fraser) covers the process quite well, this being the important bit. If you have access to a Linux machine then gparted should available from the software repo.
SN
Mon Jun 04, 2012 6:13 pm
You don't need another pc to reside the 2gb partition to the full sd card size. it can be done all on the pi itself
Steve N – binatone mk4->intellivision->zx81->spectrum->cbm64->cpc6128->520stfm->pc->raspi ?
stevepdp
Mon Jun 04, 2012 6:21 pm
Could you please elaborate SN?
itimpi
Mon Jun 04, 2012 6:34 pm
SN
Mon Jun 04, 2012 6:38 pm
thanks itmpi - it would be good if someone could script that up so make it bomb proof (against the standard debian build for example)
stevepdp
Mon Jun 04, 2012 6:48 pm
Thanks for sharing, I'll be sure to point users to that also in the future.
Johnbot
Mon Jun 04, 2012 6:52 pm
Thanks for the help, everyone! I was able to resize my partition and now my Pi has roughly 10 times the storage space! (From 1.6 to 15.7!)
itimpi
Mon Jun 04, 2012 6:53 pm
SN wrote:thanks itmpi - it would be good if someone could script that up so make it bomb proof (against the standard debian build for example)
I assume that the (currently withdrawn) Fedora distro contains that as on first time boot it resized itself to use the whole card. Might be worth seeing if the relevant code/scripts can be extracted for use on other distros.
tomjoyr
Mon Jun 04, 2012 11:17 pm
In the June issue of MagPi mag. (on page 6) Everything I did was the same except for the part that displays the partitions. Because I also used a 8 GB SD card, all the values were exactly the same. But the partition with the 1.55 GB had a hard line for a border and diagonal lines running through it. Is there reason to be concerned? I did everything on that page, and everything ran smoothly. Including checking the SHA1 number. Any thought? Don’t have the Pi yet, but I want to be ready.
Thanks, Your Pi friend, Tom
Return to “Beginners”
