simonthepiman
Running a light web server with php on the Pi
Mon Jun 04, 2012 2:03 pm
I develop in LAMP(Linux Apache Mysql and PHP) for my sins - and i thought it would be nice to setup a test environment on my Raspberry Pi so click here for simple instructions http://www.simonthepiman.com/how_to_set ... upport.php I will be adding a mysql instructions later this week if i can get it going successfully :geek:
Simon
http://www.simonthepiman.com (Beginners guides)
HansH
Re: Running a light web server with php on the Pi
Mon Jun 04, 2012 4:28 pm
I was more thinking of thttpd and sqlite (both very light)
It should not make any difference for development what is behind it...
But I usually use perl instead of php with html::templates and dbi as database abstraction..
Nice website !
simonthepiman
Mon Jun 04, 2012 5:15 pm
Thanks for the suggestions i will take a look at them as well, I use perl but am happier with php even from the command line
Simon
trn
Tue Jun 05, 2012 7:16 pm
raspbian
by default, apt-get install mysql-server (nothing change, work ok)
apt-get install php5-cli php5-common php5-fpm php5-cgi php5 php-pear php5-mcrypt php5-mysql php5-gd php-apc
apt-get install nginx (default)
all configure by default
now configure nginx to use php5-fpm to serve php file
this will use aroung 70M ram,
HansH
Tue Jun 05, 2012 8:16 pm
trn wrote:raspbian
That is why I said thttpd + sqlite < 1 M ( very light ) ;)
It just depends what you expect for load or response times....but perfect for development
so far I know nginx has also in his docs that you can use thttpd for the cgi processing.
yeah raspbian ...... great distro for the RPi
thank you mpthompson !
simonthepiman
Tue Jun 05, 2012 8:20 pm
Nice options thanks guys
Simon
HansH
Tue Jun 05, 2012 8:27 pm
np, just have fun with your RPi !
kuantum
Wed Jun 06, 2012 11:02 pm
There is my raspberry nginx + php server :) http://pi.erdur.org
