Brackets or not to Brackets
Posted: Thu Apr 03, 2014 2:29 pm
by meddyliol
Most (if not all) online Python tutorials do not use brackets, for example: print "Hello", if I do this with the raspberry it gives a syntax error. Of course writing: print("Hello") does work. Is there a reason for this? I thought that Python did away with using brackets.
Cheers
Brian
Re: Brackets or not to Brackets
Posted: Thu Apr 03, 2014 2:42 pm
by Joe Schmoe
s/brackets/parentheses/g
by rpdom
I think that is the difference between python 2 and python 3.
(I'm not a Python programmer, but I've seen it mentioned before)
Posted: Thu Apr 03, 2014 2:43 pm
by DougieLawson
Parentheses are needed for python3.
You're using python2 if it works without.
Posted: Thu Apr 03, 2014 2:45 pm
by DougieLawson
Joe Schmoe wrote:s/brackets/parentheses/g
+1
Brackets being the square ones [] and braces being the curly ones {}.
Posted: Thu Apr 03, 2014 2:58 pm
by jamesh
DougieLawson wrote:Joe Schmoe wrote:s/brackets/parentheses/g
+1
So what are ( and )?
Posted: Thu Apr 03, 2014 3:11 pm
by Joe Schmoe
As indicated above (my first post on this thread):
parentheses
Note that some of the text above is what they call a "parenthetical".
Posted: Thu Apr 03, 2014 3:42 pm
by jamesh
Nope.
All the above are brackets according to the English definition...because they all 'bracket' something...so the OP is actually correct in his use of the word brackets. If not particularly specific.
Posted: Thu Apr 03, 2014 4:15 pm
by rpdom
Brackets: ()
Curly brackets: {}
Square brackets: []
Quotey things: ""
Smiley:
Posted: Thu Apr 03, 2014 4:23 pm
by iinnovations
jamesh wrote:Nope.
While technically true, the request "please help me with my words because my little computer doesn't do what I want" is equally accurate (and difficult to process).
Posted: Thu Apr 03, 2014 10:40 pm
by DougieLawson
jamesh wrote:Nope.
Oh dear. English is losing to Merriam & Webster's egregious American Standard definitions. All is lost, I'll blame Facebook for that.
Posted: Fri Apr 04, 2014 3:39 am
by Tarcas
Let me put up a quick translation guide, based on rpdom's post:
British Symbol American
Brackets () Parentheses
Curly brackets {} Curley Braces
Square brackets [] Brackets
Quotey things "" Quotation Marks
? '' Single Quotes
? <> Angle brackets (if used as brackets. Otherwise Less Than and Greater Than)
? # Pound Sign or Hash
? ~ Tilde
Smiley :-) Smiley
Posted: Fri Apr 04, 2014 8:53 am
by chrisryall
I thought braces were what all those US teenagers have on their teeth? But I use braces to hold my trousers up
"Er, what are trousers"?
Oh,
pants!
Posted: Fri Apr 04, 2014 9:18 am
by Richard-TX
chrisryall wrote:.
Oh,
pants!
Pants from the spanish pantaloons.
Posted: Fri Apr 04, 2014 10:11 am
by piglet
Double quotes "" Quotation Marks
Single quotes '' Single Quotes
Angle brackets <> Angle brackets (if used as brackets. Otherwise Less Than and Greater Than)
Hash # Pound Sign or Hash
Pound sign (weight) lb/℔ Huh? Do you mean #?
Pound sign (money) £ Do you mean dollars?
Tilde/Squiggly thing ~ Tilde
Everyone Symbol BBC
Slash or forward slash / Stroke
Posted: Fri Apr 04, 2014 10:23 am
by jamesh
DougieLawson wrote:jamesh wrote:Nope.
Really?
http://www.oxforddictionaries.com/defin ... q=brackets
Pretty sure Oxford University Press are fairly British English.
Posted: Fri Apr 04, 2014 10:30 am
by DeeJay
All very enlightening, but to get back to helping the enquirer:
meddyliol wrote:Most (if not all) online Python tutorials do not use brackets, for example: print "Hello", if I do this with the raspberry it gives a syntax error. Of course writing: print("Hello") does work. Is there a reason for this? I thought that Python did away with using brackets.
" I thought that Python did away with using brackets."
Quite the contrary. The move from python2 to python3 made their use mandatory in some situations where they were optional before.
print is probably the most obvious example.
Posted: Fri Apr 04, 2014 1:47 pm
by Tarcas
We use lb or # for pounds weight. (usually in the grocery store you'll see prices in $/lb rather than $/#, although I have seen the latter, but usually on hand-written signs.)
I think most of us know what a £ is. But good response nonetheless.
Posted: Fri Apr 04, 2014 5:09 pm
by meddyliol
Thank you all for your informative answers. I think you have answered my question
Along with lots of other must know stuff
Cheers
Brian
P.S. Wasn't that a rather retrograde step going from Python 2 to 3 and putting brackets () back in? Everywhere online seems to do without brackets ().
Posted: Fri Apr 04, 2014 8:45 pm
by chrisryall
I can't think for the life of me think why either. This in a language that uses vacuous and tab-indistinguishable "white space" to control the more inportant "flow"
In there with those anal ';'s at the end of every line in C (or the Algol group). Javascript is cool on the issue and nothing seems to fall off
