geneworld
Using 'cat' with 'mail'
Mon Mar 31, 2014 1:41 pm
Hey guys I am working on a project and I am getting stuck on one step. I have a program that is outputting data to a *.txt file. I am looking to send the contents of that file to either my phone or email (Doesn't matter at this point.).
I know that I can use
cat "/home/pi/some_file.txt"
and it will show me the contents of the file.
I also know that
echo "Body of a message" | mail -s "This is the subject" [email protected]
will send an email. This works fine for me.
I was wondering if there is a way to send the contents of the text file as the email body. I try
cat "/home/pi/some_file.txt" | mail -s "Subject" [email protected]
and I get the following error:
mail: cannot send message: Process exited with a non-zero status
I have also tried
mail -s "Subject" [email protected] < "/home/pi/some_file.txt"
and got the same message.
Do you guys have any idea as to what I am doing wrong or what the correct line of code is?
Thanks! :D
1 B R1
4B R2 IR
1B+ USB Boot/RetroPie2.6/KODI
1Pi2 USB Boot/Media Server/Torrent Box
1Pi Zero Web-based universal remote control
2Pi Zero Misc.
1Pi3 USB Boot/RetroPie3.6/KODI/pianobar
ghans
Re: Using 'cat' with 'mail'
Mon Mar 31, 2014 2:41 pm
Tried it with the -q option ?
ghans
geneworld
Mon Mar 31, 2014 2:52 pm
ghans wrote:Tried it with the -q option ?
ghans
No I don't think that works, I'm assuming you meant to try it like
cat "/home/pi/some_file.txt" | mail -s "subject" -q [email protected]
I got the same answer.
1 B R1
4B R2 IR
2Pi Zero Misc.
Richard-TX
Mon Mar 31, 2014 3:59 pm
The rule for email is that you cannot email files that have 8 bit data in them. It has to be ascii. To send binary files they have to be uuencoded first. There are other limits.
uuencode and friends are part of the sharutils package (apt-get install sharutils)
try emailing /etc/passwd or /etc/network/interfaces. It should work
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
ghans
Mon Mar 31, 2014 5:06 pm
I actually meant
mail -s "subject" -q /home/pi/some_file.txt [email protected]
ghans
geneworld
Mon Mar 31, 2014 5:24 pm
Richard-TX wrote:The rule for email is that you cannot email files that have 8 bit data in them. It has to be ascii. To send binary files they have to be uuencoded first. There are other limits.
To be honest I am not really sure what you are talking about. I've tried
cat "/etc/passwd" | mail -s "Subject" [email protected]
and got the same error code.
1 B R1
4B R2 IR
2Pi Zero Misc.
geneworld
Mon Mar 31, 2014 5:26 pm
ghans wrote:I actually meant
ghans
Oh alright...I tried that and then i got:
mail -s "subject" -q "/home/pi/some_file.txt" [email protected]
Cc:
So I pressed Ctrl+D and I got
Cc: Null message body; hope that's ok
1 B R1
4B R2 IR
2Pi Zero Misc.
geneworld
Mon Mar 31, 2014 8:36 pm
bump for ideas! :roll:
1 B R1
4B R2 IR
2Pi Zero Misc.
blachanc
Mon Mar 31, 2014 9:07 pm
Works on red hat 4:
mail [email protected] -s trial < myfile.txt
Sorry for short post, on my phone...
Ben
Edit:
I am at work away from my PI. I tried the above
both on Linux and Unix machines and it is working.
Autism/Asperger syndrome: what is your score on this quiz?
http://www.raspberrypi.org/forums/viewtopic.php?f=62&t=70191
JustThisGuy
Mon Mar 31, 2014 9:56 pm
Regarding:
The 'cat' command is incorrect. remove the double quotes. cat is expecting a filename.
Remove the quotes on the redirect also.
Any conversation about a sufficiently complex subject is indistinguishable from babble.
wimble
Mon Mar 31, 2014 10:14 pm
JustThisGuy wrote:Regarding:
The quotes aren't a problem. They're almost certainly unnecessary, but they're not a problem. The shell processes the text by first splitting it into "words", assuming the first word is an executable, and invoking it with the other words as arguments. Special characters are space (which separates words), * and ? (which are used in filename matching), $ (which indicates a variable), double quotes (which both the space separation and wildcards, but not the variables) and single quotes (which inhibits the variable matching as well). And various other things too :)
So
cat this file
runs cat with two arguments, this and file. But
cat "this file"
runs cat with only one argument "this file", and so you can put spaces into file names (you can use backslashes . Similarly,
echo *
runs echo with multiple arguments, one for every file in the current directory, but
echo "*"
runs it with one argument: *.
It's worth noting that this is different from DOS, which doesn't do the the wildcard matching directly, but passes them unexpanded to the program. So in DOS
is ok, and will rename all your jpegs. In Linux, the equivalent
expands into a list of all your .jpg files plus a list of all your .jpeg files. So mv gets a big list of files, and complains.
Anyway. Back to the original question. Try mail with the -d argument, which (according to the man page)
-d Causes mail to output all sorts of information useful for debugging mail.
, or have a look at the files in /var/log immediately after the error, to see what they've logged.
geneworld
Tue Apr 01, 2014 12:28 pm
Hey guys good news is I got it to work finally! :mrgreen: Thanks for all your suggestions and help!
Trying
mail -d
doesn't work, I guess there isn't a debug mode in there. I tried to send a regular email and I was getting the same errors so I checked out
/var/log/mail.log
and it looked like I was having an authentication issue which was odd because before this everything was working good.
Turns out I had to add
AuthLogin=Yes
to the end of
/etc/ssmtp/ssmtp.conf
after reading this thread http://www.raspberrypi.org/phpBB3/viewt ... 8&p=386393.
Now I am able to use
:D Sorry I'm also used to just using the double quotes just so I don't have to worry about when I have spaces.
1 B R1
4B R2 IR
2Pi Zero Misc.
wimble
Tue Apr 01, 2014 4:17 pm
geneworld wrote:Trying
mail -d
Sorry about that: I was quoting from my ubuntu machine, because I don't have mail installed on my Pi. However, I'm glad you've found the problem :)
geneworld
Tue Apr 01, 2014 5:49 pm
I may have spoke too soon, I seem to be having problems staying connected to gmail or something cause I keep getting that and an authentication error...I'll have to look into it when I get home it gets annoying doing it from my phone :cry: :lol:
1 B R1
4B R2 IR
2Pi Zero Misc.
JustThisGuy
Tue Apr 01, 2014 7:46 pm
Don't worry about the quotes. I'm the exact opposite. I don't use them unless absolutely positively necessary. Wimble's right, in this case they aren't an issue.
