Mon Mar 31, 2014 9:02 am
ilaam wrote:Hi,
I am trying to use RPi to emulate a set of sensors ( a set of slaves). So I need to make it run in I2C slave mode and it should have more than one I2C address (an address per sensor). I wont be using any sensor, it is the RPi that commuicate with a master shipset and responds every time as a different sensor.
To summarize, is it possible to assign many I2C addresses to the RPi ?
Thank you
AFAIK, No, because the RPi
always works as an I2C master ie., IIRC, cannot** be used as an I2C slave.
Trev.
** except, perhaps, by writing your own I2C "driver" and not using the supplied kernel modules.
