stujol
lpconfig
Mon Mar 24, 2014 7:00 pm
I'm installing a script and one of the warnings is:
If you are installing Swift system-wide, you may need to add the following
line to /etc/ld.so.conf and run ldconfig as root:
/opt/swift/lib
(Otherwise, you will need to add it to the LD_LIBRARY_PATH environment
variable in order to run programs linked against the Swift libraries.)
Can someone please give me step by step instructions on how to do this please.
stujol
Re: lpconfig
Mon Mar 24, 2014 7:14 pm
error im getting is
Testing the installed swift binary...
/opt/swift/bin/swift -o /dev/null 'hello world'
install.sh: 267: install.sh: /opt/swift/bin/swift: not found
DeeJay
Re: lpconfig
Mon Mar 24, 2014 7:17 pm
It's NOT ipconfig!
Which part of the instructions can you not do?
Do you know how to edit a text file? If not, choose a text file editor ( leafpad, nano, vi... ) and learn how to do basic changes with it.
Then make the specified addition to the named file.
stujol
Re: lpconfig
Mon Mar 24, 2014 7:30 pm
I've edited ld.so.conf, so now looks like
include /etc/ld.so.conf.d/*.conf
/opt/swift/lib
not sure on the format of lpconfig within the LXTerminal window to allow it to update
DeeJay
Re: lpconfig
Mon Mar 24, 2014 9:17 pm
It isn't 'lpconfig' either!
For most commands, entering
man <your command name>
will explain the options and how to use the command.
Now you have posted your error message, I don't think any of this helps...
That looks as though it is trying to run a file with an explicit name of /opt/swift/bin/swift, but no such file exists on your system.
Are you sure that the installation instructions you are following are relevant for the (unidentified) Operating System you are using on your RPi?
wimble
Re: lpconfig
Mon Mar 24, 2014 10:57 pm
stujol wrote:not sure on the format of lpconfig within the LXTerminal window to allow it to update
I'll second everything DeeJay has said. However, the answer to your original question on how to run ldconfig is simply:
sudo ldconfig
That's all you need: no parameters, nothing else. By default, ldconfig reads /etc/ld.so.conf which you've already changed. So there's nothing else to do. However, that won't fix the error message you're getting: as DeeJay says, swift isn't where you think it is.
stujol
Re: lpconfig
Tue Mar 25, 2014 5:44 pm
if I type in man swift, I get all the options listed.
using the file viewer, I can navigate to /opt/swift/bin/ and i have 4 filrs within this folder
cepstral-licsrv - shell script
cepstral-licsrv.bin - unknown
swift - shell script
swift.bin - unknown
/opt/swift/bin has a owner and group of 'root; with read and write to owner, read only to group and others.
the contents of /opt/swift/bin/swift is (only opens in leafpad, not nano)
#!/bin/sh
set -e
SWIFT_HOME="/opt/swift"
LD_LIBRARY_PATH="/opt/swift/lib"
SWIFT_BIN="opt/swift/bin"
export SWIFT_HOME
export LD_LIBRARY_PATH
exec "$SWIFT_BIN/swift.bin" ${1+"[email protected]"}
The company who made the files (Cepstral) are also struggling with this error message.
im using:
[email protected] ~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 7 (wheezy)"
NAME="Raspbian GNU/Linux"
VERSION_ID="7"
VERSION="7 (wheezy)"
ID=raspbian
ID_LIKE=debian
ANSI_COLOR="1;31"
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
sing file viewer, if I right click on the swift file located in /opt/swift/bin/ and click open, then click the execute button, I get an error saying 'failed to execute child process "opt/swift/bin/swift" (no such file or directory)
Don't know if any of the above will be of any help?
stujol
Re: lpconfig
Tue Mar 25, 2014 5:57 pm
[email protected] ~$ man swift - returns the help file in what seems to be in edit mode
[email protected] ~$ swift --voices - returns bash: /user/local/bin/swift: /bin/sh^M: bad interpreter: no such file or directory
[email protected] ~$ swift --help - returns bash: /user/local/bin/swift: /bin/sh^M: bad interpreter: no such file or directory
stujol
Re: lpconfig
Tue Mar 25, 2014 6:01 pm
found a copy of swift in /usr/local/bin but it has what I would call a shortcut icon on the file, black arrow top left corner. if I right click, then click the execute button, I get an error saying 'failed to execute child process "usr/local/bin/swift" (no such file or directory)
stujol
Re: lpconfig
Tue Mar 25, 2014 6:03 pm
unable to find a /local/ directory
d_older
Re: lpconfig
Tue Mar 25, 2014 8:19 pm
Hi Stujol
A couple of things I've noticed.
1) Some scripts seem to have DOS line endings (^M), which may be the cause of the "bad interpreter" messages, sudo apt-get install dos2unix and then run that against all scripts with ^M in them. ( may need to be root /sudo)
On my system ls -al /bin/sh gives /bin/sh -> dash
2: in /opt/switft/bin/swift, the line
seems to be missing the / in front of opt
again you may need root/sudo to correct this.
Hope this helps,
Dave.
