billybob01
SSH login refused from Linux PC
Fri Jun 01, 2012 4:33 pm
I have XBMC running on a PI at last and have been SSHing from a windows PC just fine.
I tried to SSH from a laptop running Puppy Linux and I get a warning message that the Remote Host Identification has changed.
The message tells me I have to change the SSH key in a directory that doesn't exist. I found a debian instruction somewhere telling me to delete the SSH files that hold the keys and regenerate the keys. I couldn't even delete the files.
Can anyone tell me how to SSH in from the Puppy machine?
andyl
Re: SSH login refused from Linux PC
Fri Jun 01, 2012 8:09 pm
Are you specifying an IP address with your ssh or a host name?
If an address could you have ssh'd onto a machine in the past with the same IP address that your pi now has?
If a name could you have ssh'd onto a machine (or VM) with the same name?
You will have to alter the known_hosts file on your Linux PC. Login and change directory to .ssh
edit known_hosts and remove the offending line.
snaipperi
Sat Jun 02, 2012 12:11 pm
Use something like
ssh-keygen -R 192.168.1.5
where 192.168.1.5 is the host you're trying to connect to. Replace as necessary. the -R switch stands for remove. The defined host is removed from your known_hosts file.
Alternatively like andyl said, you need to manually remove the offending line in ~/.ssh/known_hosts file. "~" is a shortcut for your home directory.
The error is caused when there is a different system running behind the same host you've connected to before. You can cause this situation for example when re-installing the base system or regenerating new SSH key pairs. This security measure exists to make sure that you don't accidentally connect to a "wrong machine", potentially exposing your security credentials to an unknown party. (Correct me if I'm wrong!)
billybob01
Sat Jun 02, 2012 2:39 pm
Ah thankyou both so much.
The problem occurred after I SSH'd onto the PI with a different SD card. Because I couldn't get my wifi adapter working under Raspbmc I switched to a straight debian image and couldn't SSH in.
I was trying to change the known hosts on the PI. I didn't realise I was supposed to be doing it from the Linux PC.
Your -R command worked beautifully and I am now up and running. XBMC is working like a dream.
TyNick
Fri Sep 14, 2012 1:51 am
Just wanted to say thanks, this post/answer helped me out.
PatrikJarl
Thu Nov 28, 2013 1:50 pm
Awsome! This was my final step to connect to my RaspPi headless for the first time! Txs for sharing guys!
wdihtcai
Wed Nov 19, 2014 12:38 am
A great post. I encountered the message " WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!" when I booted up weezy-raspian from a new micro-sd card. Your suggestion:
ssh-keygen -R "netaddress" (10.0.1.7 in my case) worked perfectly. I was able to ssh into my raspberry PI as before.
THANKS!
-Theush-
Thu Aug 06, 2015 6:34 pm
Thanks for this post/answers!! Keep up the good work!
