Wed Mar 12, 2014 2:45 pm
The op is a bit ambiguous. Do you mean the Pi has its own LAN as an access point , or that it is a member of the LAN that your home gateway administers? I am going to assume the latter.
In any case I echo the reco for iptables and/or ufw, but unless you route traffic TO your Pi intentionally from your router via DMZ or port forwarding, only other members of the LAN can see it, i.e. no WAN inbound traffic (except responses to your http requests, etc). Now if you want to block all outbound traffic (visibility to WAN FROM the Pi), follow the advice above and use ufw to restrict all traffic to your local subnet, e.g. 192.168.1.1/24 or whatever your subnet is. I personally don't see the need for this, and you won't get updates, etc., but you know your usage better than I.
Colin
CuPID Controls :: Open Source browser-based sensor and device control
interfaceinnovations.org/cupidcontrols.html
cupidcontrols.com
