Wireless IP Setup
Posted: Mon Mar 10, 2014 3:43 am
by SerenityNetworks
I'm having difficulty setting up my RPi to use wireless. I've gone to sudo nano /etc/network/interfaces and entered:
auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.0.82
netmask 255.255.255.0
broadcast 192.168.0.255
gateway 192.168.1.254
auto wlan0
allow-hotplug wlan0
wpa-ssid "myssid"
wpa-psk "mypassword"
The setup works fine for Ethernet, but not wireless. My router's security mode is "WPA2 Personal". Encryption is "TKIP or AES".
Is my configuration string incorrect &/or how do I troubleshoot? I'm suspecting I need to change the last two lines of the configuration string, but I'm not sure to what.
Thanks in advance,
Andrew
Re: Wireless IP Setup
Posted: Mon Mar 10, 2014 9:09 am
by MrEngman
If you are trying to connect both at the same time, especially if you are trying to configure it with the ethernet connected, then I suggest you give each interface a different IP address. And of course "myssid" and "mypassword" will be the name and password of your wifi network.
You can check the wifi can work using the command
sudo iwlist wlan0 scan
This should show a list of nearby networks if the wifi adaptor is OK and the driver is loaded and installed OK.
MrEngman
Posted: Mon Mar 10, 2014 9:13 am
by MrEngman
Also you don't really need both
auto wlan0
allow-hotplug wlan0
One should be sufficient. I always use
allow-hotplug wlan0
MrEngman
Posted: Mon Mar 10, 2014 5:20 pm
by SerenityNetworks
I'll need to follow up on this later tonight when at home, but here are a few notes:
- I installed using NOOBS.
- I'm using the Edimax (EW-7811UN) adapter recommended.
- Once I get wireless working then I will seldom go back to Ethernet (although sometimes I will still use Ethernet, so I don't want to lose the functionality and I want to keep the IP static).
- I have not done anything to configure the adapter (I thought this one was plug 'n' play with the RPi.
- Yes, the "myssid" and "mypassword" are just placeholders for the real values.
Thanks,
Andrew
Posted: Mon Mar 10, 2014 6:15 pm
by RobHenry
One more point - you are defining eth0 twice.
iface eth0 should be wlan0 the second time it appears
Posted: Mon Mar 10, 2014 9:54 pm
by MrEngman
Hi RobHenry
True, didn't notice that. Must get some new spectacles ;)
Hi Andrew
I've just tried one of my Pi's with fixed IP's and it all appears to work OK using the following
auto lo
address 192.168.16.150
gateway 192.168.16.2
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.16.151
wpa-ssid "network-name"
wpa-psk "network-password"
Also noted in your file the address is 192.168.0.82 but the gateway is 192.168.1.254 which would put the gateway on a different network. I would expect the first 3 numbers to be the same, either 192.168.0.xxx for both or 192.168.1.xxx with xxx being the final number of each IP.
MrEngman
Posted: Tue Mar 11, 2014 1:55 am
by SerenityNetworks
Thanks. I obviously had some typo's in the configuration. (And I just got new spectacles!)
Anyway, following is the code I entered as-well-as the result of the scan. I can PuTTY using Ethernet without any issues. But I still cannot connect via WiFi.
I'm not sure where to go from here.
Thanks,
Andrew
auto lo
address 192.168.1.82
allow-hotplug wlan0
address 192.168.16.83
wpa-ssid "WRT160N-Gadget"
Using username "pi".
pi@192.168.1.82's password:
Linux raspberrypi 3.10.25+ #622 PREEMPT Fri Jan 3 18:41:00 GMT 2014 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue Mar 11 01:37:46 2014 from primarydesktop
pi@raspberrypi ~ $ sudo iwlist wlan0 scan
wlan0 Scan completed :
Cell 01 - Address: 00:23:69:D3:2B:11
ESSID:"WRT160N-Gadget"
Protocol:IEEE 802.11bgn
Mode:Master
Frequency:2.412 GHz (Channel 1)
Encryption key:on
Bit Rates:300 Mb/s
Extra:wpa_ie=dd1c0050f20101000050f20202000050f2040050f20201000050f2020c00
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (2) : CCMP TKIP
Authentication Suites (1) : PSK
Extra:rsn_ie=30180100000fac020200000fac04000fac020100000fac020c00
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : TKIP
IE: Unknown: DD6F0050F204104A00011010440001021041000100103B00010310470010EB335F51E5596683907CEE504DED001C102100074C696E6B737973102300075752543136304E102400063132333435361042000234321054000800060050F2040001101100075752543136304E100800020084
Quality=100/100 Signal level=100/100
Posted: Tue Mar 11, 2014 2:34 am
by MrEngman
Hi Andrew,
iwlist shows the wifi is working as it lists your network so you're getting close to getting the wifi networking running.
Just one thing - in your current /etc/network/interfaces it shows wlan0 IP address is defined as 192168.16.83. Is that right or a typo? 192.168.1.83 would be more useful.
One thing I've found when changing networking settings is it sometimes helps to run the two commands
sudo ifdown wlan0
sudo ifup wlan0
or
sudo ifdown --force wlan0
sudo ifup --force wlan0
which are rather more persistent. And often repeating them more than once can then get things up and running properly.
MrEngman
Posted: Tue Mar 11, 2014 2:45 am
by SerenityNetworks
Whoohoo! I'm in.
I'm going to have to talk to my eye doctor. She obviously got my recent prescription wrong. I know I proofed that config file more than once. "192168.16.83" sure looked to me like "192.168.1.83" :oops:
Thanks for catching my mistake. Correcting the typo' and running your tips had it working in seconds. I am now headless via WiFi.
Thanks again,
Andrew
