[HELP] Cannot access webpages from apache server via Interne
Posted: Sat Mar 08, 2014 5:52 am
by edwardbai93
Hello everyone. I am a beginner with Pi and Apache servers. I recently installed apache server on my Pi, and when I access it from LAN, I got the "It works!" default page.
However, I could not access the webpage through the internet. I already have a DDNS: xxx.dlinkddns.com, and I setup the port forwarding (port 80) on my router. It did work for remote SFTP access after I opened port 22 :geek: .
The index.html is set in default in /var/www, but I cannot open it via Internet by typing http://xxx.dlinkddns.com/index.html. Are there any solutions to this problem? Thanks guys.
Re: [HELP] Cannot access webpages from apache server via Int
Posted: Sat Mar 08, 2014 8:48 am
by DougieLawson
Test your port forwarding at: http://www.yougetsignal.com/tools/open-ports/
Does your RPi have a fixed IP address on your LAN? Is the right address forwarded in your router?
Is Apache listening? Test it with http://localhost or http://192.168.1.xx or netstat -tln
Posted: Sat Mar 08, 2014 9:34 am
by edwardbai93
DougieLawson wrote:Test your port forwarding at: http://www.yougetsignal.com/tools/open-ports/
Hi DougieLawson, I typed the code you said: netstat -tln
And I got:
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN
And I tried to List only listening TCP Ports using netstat -lt. The results are:
tcp        0      0 *:ssh                   *:*                     LISTEN
tcp        0      0 *:microsoft-ds          *:*                     LISTEN
tcp        0      0 *:netbios-ssn           *:*                     LISTEN
tcp        0      0 *:http                  *:*                     LISTEN
Does that mean my TCP port 80 is listened by Apache? I am sure that I used DHCP to give my pi a static IP: 192.168.0.2. I can access this IP with a LAN computer using Putty/WinSCP. I am sure that my port forwarding is set like this, and the port 22 is working during remote access:
  • SFTP tcp 192.168.0.2 22-22 22-22 Enabled
    WEB tcp 192.168.0.2 80-80 80-80 Enabled
What else could possibly be wrong? I've been confused all day long... :? :? :?
Posted: Sat Mar 08, 2014 9:37 am
by DougieLawson
What do you get from that yougetsignal web site?
Your system is running sshd, a web server and cifs/samba.
Can you access http://192.168.0.2 from your Windows machine?
Posted: Sat Mar 08, 2014 9:59 am
by edwardbai93
DougieLawson wrote:What do you get from that yougetsignal web site?
My Pi does not have an external IP address, so I used the DDNS domain (mydomain.dlinkddns.com), and it said that Port 80 is closed. Nor was it on after I typed 192.168.0.2 (LAN IP).
And a funny thing to mention, all devices that is connected to the same router (LAN devices) CAN open the page from http://mydomain.dlinkddns.com or http://192.168.0.2. But any device that is not connected to the router will fail to acess. Wonder what is going on here. I did not intended to make a web server just for the LAN :? :? :(
Posted: Sat Mar 08, 2014 11:35 am
by DougieLawson
When you're asleep your ISP does a sneaky thing - they disconnect your system. When you start using the internets again they reconnect. There are two possible things that happen at that point.
1. You get the same public IP address
2. They assign a new public IP address
When you run a dynamic DNS service you need to detect #2 and react to it. Your dyndns server will have a script to run to update your registration when your public IP address changes. That script can either run on your router or can run on your RPi.
Posted: Sat Mar 08, 2014 11:48 am
by edwardbai93
DougieLawson wrote: 1. You get the same public IP address
My ISP gives me a static IP address (external), and I feed it to my router's WAN port. Both my PC and Pi are connected to the router by cable, and assigned with DHCP static IP address.
I am just wondering why my SFTP (Samba) works on my Pi in remote access, but my Web server fails. :(
Posted: Sat Mar 08, 2014 12:03 pm
by ripat
Have you set up any kind of filtering/access control by host like:
- TCP wrapper (inetd's hosts.deny & hosts.allow) ?
- iptables ?
- apache mod_authz_host ?
Posted: Sun Mar 09, 2014 4:14 am
by edwardbai93
ripat wrote:Have you set up any kind of filtering/access control by host like:
- iptables ?
No, I don't think so... I don't recall blocking port 80 through any of these ways
Posted: Sun Mar 09, 2014 6:54 am
by ripat
According to your description of the problem, it is not the port that seems to be blocked but the client's IP when they try to connect to your server from outside. But, just to make sure your ISP doesn't block the port 80, you can try to change the port Apache listen on.
If no luck with that, investigate on the mod_authz_host module. Look for directives like Allow from... | Deny from... in the apache config file.
Check both the /etc/hosts.allow and /etc/hosts.deny files for any httpd filters
Dump the iptables (sudo iptables -vS) and search for any rule that might block the frames from outside your lan.
Posted: Sun Mar 09, 2014 9:59 am
by edwardbai93
ripat wrote:According to your description of the problem, it is not the port that seems to be blocked but the client's IP when they try to connect to your server from outside. But, just to make sure your ISP doesn't block the port 80, you can try to change the port Apache listen on.
I checked /etc/apache2/ports.conf, and port 80 is always being listened. I also checked with nmap -h 80 -sT mydomain.com, which showed Port 80 is open.
ripat wrote:If no luck with that, investigate on the mod_authz_host module. Look for directives like Allow from... | Deny from... in the apache config file.
I didn't see any port 80 or my hosts that is denied. :cry:
ripat wrote:Check both the /etc/hosts.allow and /etc/hosts.deny files for any httpd filters
The files were unchanged, and blank.
ripat wrote:Dump the iptables (sudo iptables -vS) and search for any rule that might block the frames from outside your lan.
Sorry I'm not really clear on this one. Could you give me a little hints? My iptables (and iptables-persistent) seems to be unsuccessfully installed due to some errors.
Thanks a lot! :|
Posted: Sun Mar 09, 2014 11:02 am
by ripat
There is a typo in your command. The option to scan a particular port is -p, not -h. But anyway, your port scan might not mean anything. Did you do it from inside your lan with your public ddns domain name? In that case, most routers do not enable the NAT reflection/loopback mode for requests sent from within the lan. Check the apache access log to see under which IP the scan was logged, a lan IP or your public ip? As I mentionned above, your ISP might block the port 80 for some reason. Try to change the port Apache server listen on and see if it makes any difference. On a typical Debian installation, you set that up in the /etc/apache2/ports.conf file. Try port 888 for example. Don't forget to reload the config file: $ sudo /etc/init.d/apache2 reload
Just to make sure, run: $ grep -ri '\(allow\|deny\) from' /etc/apache2/*
iptables is then probably not active.
Re: [HELP] Cannot access webpages from apache server via Interne
Posted: Thu Dec 19, 2019 8:50 pm
by schenk
Greeting all:
I am having the same issue after installing buster. I'm using all Ubiquiti router, switches, etc. I can ssh in through port forwarding OK, and access several port forwarding rules, but apache will not work to my two Raspberry pi Buster machines. When I check to see if port 80 is open (from the outside) it is not with the port forwarding rules to my Raspberry pi. But it is from with in the lan. I can access other web pages on my local network with other ports forwarded to other machines on the local network. So I am thinking that it is an issue with buster/apache.
If anyone has solver this issue, or can give me some insight, I would be very grateful!
Laurence
