eyespie
How can I restrict ftp on raspbmc?
Wed Mar 05, 2014 8:27 am
Hello there, I want to know how I can go about limiting the folders that the ftp service raspbmc accesses. At present it offers up the complete root directory which makes me feel a little uneasy. I want to restrict it to a usb stick in /media/.
I've looked at some tutorials online and played with installing vsftpd in raspbian without problems. It was my impression that raspbmc used vsftpd because vsftpd.conf exists in /etc/ by defualt. But when I edit the the file i can't seem to get anywhere. Furthermore, when I try to stop/start the service it says vsftpd is not installed. Why the config file? Is it just a dummy? Any thoughts on what to do next would be helpful. Thanks.
Angelus88
Re: How can I restrict ftp on raspbmc?
Wed Mar 05, 2014 2:11 pm
Try:
sudo apt-get remove --purge vsftpd*
sudo apt-get install vsftpd
This way we can reinstall the ftp server.
After that, you have to change vsftpd.conf file in order to have:
chroot_local_user=YES
local_root = /media/usbstickfolder
and then restart the service:
sudo service vsftpd restart
eyespie
Fri Mar 07, 2014 6:07 am
Thank you for your reply Angelus88 but it didn't seem to solve the problem.
I followed the instructions.
sudo apt-get remove --purge vsftpd*, then reinstalled and added the two to the new configuration file /etc/vsftpd.conf.
When I tried access the server via filezilla on another computer I got an error:
Response: 500 OOPS: vsftpd: refusing to run with writable root inside chroot()
Error: Critical error
Error: Could not connect to server
I tried to google the error and read somewhere you need to create folders within the root folder such as /usbstick/ftp/files. I didn't work for me.
I tried adding allow_writable_root=YES but that all seemed to have no effect.
After trying a few other things - such as attempting to install and uninstall and start from scratch I'm a bit confused. I can't call up the service - if I try sudo service vsftpd start and then sudo service status I get vsftpd is not running.
If I try sudo apt-get remove --purge vsftpd* again the system states:
E: Unable to locate package vsftpd.conf
E: couldn't find ange package by regex 'vsftpd.conf'
but if I try to install then - the system states: "vsftpd is already newest version".
whereis vsftpd results in : /usr/sbin/vsftpd /etc/vsftpd.conf /usr/share/man/man8/vsftpd.8.gz
Fri Mar 07, 2014 8:32 am
sudo apt-get purge "vsftp*"
Are you aware that ftp is one of the bigger security holes and that sshd provides sftp support for free, already installed and ready to go?
