/etc/fstab ArchlinuxArm
Posted: Wed Mar 05, 2014 7:42 am
by WoldemarShiPa
Hello. I want to set mount flags for my /dev/root, but /etc/fstab doesn't contain /dev/root entry (mounted by VFS). How can I do it? Simply add that line? Thanks.
Re: /etc/fstab ArchlinuxArm
Posted: Thu Mar 06, 2014 8:12 am
by sdjf
Hmm, I see what you mean. I would guess you can try adding a line, as long as your syntax is correct. But you could also render the rootfs inaccessible, so be careful.
But studying my /etc/fstab on arch, it looks like you had better do something starting with the following if using /dev/root does not work, because it really is the whole second partition. I think /dev/root is a symlink to it???
/dev/mmcblk0p2 /
EDIT: I looked at output of mount command, the output for root partition is:
/dev/mmcblk0p2 on / type ext4 (rw,relatime,data=ordered)
But I am not sure this is the right way to do that, is there something you could put into /boot/cmdline.txt that would accomplish what you need?
