nickeh
4066 CMOS switch
Mon Feb 24, 2014 5:28 am
I want to use a GPIO (output) to switch a 4066 (control input). Can I connect a GPIO output directly to the control pin or do I need a resistor in between? And how should it be connected (resistor between GPIO and control pin or how)?
Thanks in advance!
Paul Moir
Re: 4066 CMOS switch
Mon Feb 24, 2014 7:34 am
You can directly connect. No need for a resistor.
That said, what are you supplying your 4066 at? At 5v you need 3.5v minimum on a control line to switch it on, so you would have to level shift in that case. Check the datasheet and you'll see what I mean.
EDIT: You know, the 74HCT4066 (but not the 74HC4066) is guaranteed to switch on with a 2v control with 5v Vcc. I guess it depends on exactly what you're trying to do though.
nickeh
Mon Feb 24, 2014 8:51 am
Thanks Paul,
I have the HCF4066BE and I was thinking of running it on 3.3V since it can work from 3-20V. Lets see if it works :)
Best regards
Nicke
Paul Moir
Mon Feb 24, 2014 6:22 pm
Ok, no problem then with a 3.3v power supply. At least I think it should work perfectly normally down that low. The "On" state resistance gets higher as Vdd drops, so I guess you can expect a few K across each switch.
nickeh
Mon Feb 24, 2014 7:39 pm
Yes, it worked perfectly with one 4066. I am hoping to power two 4066 from the RPi 3.3V, according to the specs the power need is really low so it should not be a problem. Across the switches I measured 190 ohms which was less than I expected.
Thanks for your support Paul
