dpadilla711
is sandisk extreme hd video sd card compatible?
Fri Feb 21, 2014 1:32 am
hello everyone, i wanted to know if any one knew if this sandisk extreme hd video sd card is compatible with the raspberry pi. its model number is sdsdrx3-8192-A21. i checked some compatibility sites but i could not find this exact one. thank you in advance for your help. :D :!: :D :P :shock: 8-)
mahjongg
Re: is sandisk extreme hd video sd card compatible?
Fri Feb 21, 2014 2:09 am
changed non descriptor subject line to one that hight get readers to notice.
many people will never read more than your subject line, so it must ask the actual question, or it won't be noticed.
forgeflow
Fri Feb 21, 2014 5:58 am
There's a good chart of cards here: http://elinux.org/RPi_SD_cards. Scrolling way down that page you'll see some performance results. It looks like the RPi tops out around 20 MB/s speed reading from an SD card, so honestly, in my opinion, anything over Class 6 is a bit of a waste. Mind you, these days there's not a lot of spread in prices so a basic Class 10 should be a safe purchase, as long as it's not more expensive than the same size in a class six. BTW, all the words like "Ultra', 'Extreme', 'Professional' are just marketing BS. The Class determines the speed, and anything above 4Gb has to be SDHC and anything above 32Gb has to be SDXC. SanDisk is the largest manufacturer of SD Cards, so they are a target of counterfeiters - don't buy cheap SanDisk cards from sketchy looking deals on eBay. Lexar is a good brand, recommended by some camera manufacturers, and I've never had a problem with a Lexar SD Card.
