Wed Feb 19, 2014 10:50 pm
jojopi wrote:There is an extra problem with the type in the original picture. Even if it meets its specifications, it only needs to provide 5V 1A at its socket. USB A to µB cables are only required to carry 500mA at the allowed voltage drop. (Even assuming they are are not themselves rubbish!) So if the supply provides 1A, the voltage may be out of spec at the other end of the cable.
Power supplies with a captive cable are likely to be better because then their specification applies to the plug end.
(Having said that, I have several Pies powered from PCs and TVs using USB A to µB cables. That is technically out of spec. It requires cables that exceed the USB specification. No seller ever specifies the resistance of a USB cable, but if you buy enough you find that some are very good and some are very poor.)
I'd not come across the "500mA requirement" (but then, being retired, I don't read "formal specs." much these days
). You may be interested to discover that (at least for the ones I've measured) USB A to mini-B cables are worse - FWIW, my, fairly basic, measurements of a number of cables can be found at:
http://www.cpmspectrepi.webspace.virgin ... esChk.html
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, A+ and a B2) but Buster on the P4B's. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
