My laptop can't recognize the RaspberryPi SD card
Posted: Sat Feb 15, 2014 1:35 am
(This was already posted on another thread, but I don't know if I can get help quicker if I just start a new thread on my RaspberryPI issues.) Hi. A complete Raspberry PI dummy here. I believe this is a good place (if not the only right place) to post this here.
I'm having a number of problems getting my Raspberry PI up and running. I've looked over the quick start guide, and it looks like there is a lot for me to do to accomplish that task.
I got to the business, and I'm already having a problem: my laptop will not see the RaspberryPI-branded SD card. I (1) plugged it into my laptop and (2) used the SanDisk card reader - nothing worked.
In my Ubuntu terminal I wrote:
... nothing happened. No output on the terminal. Then I wrote:
... and it spat out a bunch of stuff that is just over my head.
Any help would be appreciated. If you need any more clarification or if you think this should be in a different sub-forum or thread where I could get more help (especially from a person who is an expert with SD cards), please let me know.
- Cheers, Andrey.
sudo su -l
echo 1 > /sys/bus/pci/rescanCode: Select all
lspci -vvnnAny help would be appreciated. If you need any more clarification or if you think this should be in a different sub-forum or thread where I could get more help (especially from a person who is an expert with SD cards), please let me know.
- Cheers, Andrey.
