skydive
GPIO problems?
Fri Feb 14, 2014 1:46 pm
Hello!
We are a group of 4 who are currently working on a laser-communicator that will be connected to the GPIO. The communicator will work like this: A laser will be connected to the GPIO slot 7 and to GND. Now we will make it blink via a morse technique so that you can write simple text and send it by light basically. The problem we have right now is that the gpio is to slow for our demand, we can go for maximum 1000Hz or lower, otherwise the signal becomes to difficult to read. We believe that it is the Raspberry itself that can't handle higher frequencies, but at same time it should be able to go much faster. Suggestions?
Best regards
DeeJay
Re: GPIO problems?
Fri Feb 14, 2014 5:47 pm
There is a report of some benchmarking here - http://codeandlife.com/2012/07/03/bench ... pio-speed/
That blog item is 18 months old and things may have changed since, but the code seems to be online so you could reproduce the tests. The results seem much more optomistic than what you are reporting: maybe your chosen output device is slow to light up and fade?
skydive
Re: GPIO problems?
Fri Feb 14, 2014 7:33 pm
We didnt have any devices nor lasers in that test, it was simply made by connecting the osciloscope directly to the output 7 of the GPIO. Image So, if you look at the third and fourth picture we've tested the frequency 10000Hz directly from the Pi, it's hard to see it from the pictures, but it stutters and gitters alot back and fourth, giving us a really hard signal to translate. Picture 1 and 2 is from the reciever which is a photodiode, transmitted from the pi with a laser attached to GPIO 7 (which is tested and can maintain a frequency on 1Mhz). As the pictures are showing us, the signal is really irregular and hard to translate.
Suggestions on what the problem can be? (Using the Rpi.GPIO python)
Best regards
Kirk Fraser
Re: GPIO problems?
Fri Feb 14, 2014 7:56 pm
You might want to look at a Parallax Propeller microcontroller for your application. I think you'll find a more satisfactory O'scope response but as DeeJay wrote, getting that speed into a slow laser light-up and fade is another problem. I'm assuming you're going with a solid-state laser diode for speed instead of an externally pumped crystal, gas or liquid laser.
joan
Re: GPIO problems?
Fri Feb 14, 2014 8:21 pm
#!/usr/bin/env python
import pigpio
GPIO=22
MICROS=200000
NONE=0
DASH=3
DOT=1
GAP=1
LETTER_GAP=3-GAP
WORD_GAP=7-LETTER_GAP
pigpio.start()
morse={
'a':'.-'   , 'b':'-...' , 'c':'-.-.' , 'd':'-..'  , 'e':'.'    ,
'f':'..-.' , 'g':'--.'  , 'h':'....' , 'i':'..'   , 'j':'.---' ,
'k':'-.-'  , 'l':'.-..' , 'm':'--'   , 'n':'-.'   , 'o':'---'  ,
'p':'.--.' , 'q':'--.-' , 'r':'.-.'  , 's':'...'  , 't':'-'    ,
'u':'..-'  , 'v':'...-' , 'w':'.--'  , 'x':'-..-' , 'y':'-.--' ,
'z':'--..' , '1':'.----', '2':'..---', '3':'...--', '4':'....-',
'5':'.....', '6':'-....', '7':'--...', '8':'---..', '9':'----.',
'0':'-----'}
def transmit_string(gpio, str):
   pigpio.wave_clear() # start a new waveform
   wf=[]
   for C in str:
      c=C.lower()
      print(c)
      if c in morse:
         k = morse[c]
         for x in k:
            if x == '.':
               wf.append(pigpio.pulse(1<<gpio, NONE, DOT * MICROS))
            else:
               wf.append(pigpio.pulse(1<<gpio, NONE, DASH * MICROS))
            wf.append(pigpio.pulse(NONE, 1<<gpio, GAP * MICROS))
         wf.append(pigpio.pulse(NONE, 1<<gpio, LETTER_GAP * MICROS))
      elif c == ' ':
         wf.append(pigpio.pulse(NONE, 1<<gpio, WORD_GAP * MICROS))
   pigpio.wave_add_generic(wf)
   pigpio.wave_tx_start()
pigpio.set_mode(GPIO, pigpio.OUTPUT)
transmit_string(GPIO, "HEllo world")
pigpio.stop()
International morse code. Unit set at 200,000 micros for testing. MICROS should be even, minimum value 2.
The code is not particularly clever, successive gaps should be combined into one pulse rather than 2 or 3.
Unit of 4 milliseconds
boyoh
Re: GPIO problems?
Sat Feb 15, 2014 10:17 pm
skydive wrote:Hello!
Best regards
What is the Morse Technique you are using ?
BoyOh
BoyOh ( Selby, North Yorkshire.UK)
Some Times Right Some Times Wrong
Re: GPIO problems?
Sat Feb 15, 2014 10:31 pm
Why Morse? Even EBCDIC is better defined than Morse.
With any serial link you should use 8N1 ASCII. With a wired connection you can easily get the RPi running at 115,200 bps.
Your laser is just a faster serial link.
Raspruss
Re: GPIO problems?
Sat Feb 15, 2014 11:10 pm
Without doing ANY thinking about the problem, none-the-less a related question: Wouldn't the Pi have significant "interference" problems with multitasking, thus the higher frequency tests having "glitches" and "jitter"?
hampi
Re: GPIO problems?
Sat Feb 15, 2014 11:41 pm
DougieLawson wrote:Why Morse? Even EBCDIC is better defined than Morse.
That depends on the communication channel used. These channels can distort the signal quite a bit and there is usually some noise present too. The morse is one of the so called fuzzy modes which rely on human brain (kind of neural network) to interprete the message.
joan
Re: GPIO problems?
Sun Feb 16, 2014 8:41 am
Raspruss wrote:Without doing ANY thinking about the problem, none-the-less a related question: Wouldn't the Pi have significant "interference" problems with multitasking, thus the higher frequency tests having "glitches" and "jitter"?
That's why I suggested the use of pigpio. pigpio waveform, servo, and PWM functionality is unaffected by Linux scheduling jitter.
