I have read through most of the instructions but have not found my problem: I think I successfully copied all the NOOB files to my SC card (following instructions on http://www.cpmspectrepi.webspace.virgin ... ying_Files). When I installed the SD card and then turned on (plugged in) the Pi, I saw the pretty rainbow colours and then a message about connecting to the internet (which I did not do as I don't want to be on-line yet) and then got stuck with an empty square with the header "Noobs v.1.3.2 built November 2, 2013". Below the header are 4 little icons in a row: install, edit config, online help and exit. None of the icons responds when clicked. Underneath is the large empty box into which it would seem I could type something but nothing appears when I type. Beneath the box is a language drop-down and a keyboard drop-down to select language and keyboard type. That's it. Nothing else appears on the screen.
I thought perhaps the keyboard wasn't powered correctly but when I press 1 and 2 I get changes to the screen (1 makes the box smaller and 2 expands to full screen)
I would be grateful for suggestions of what I can do now!
