Resizing partitions
Posted: Tue May 29, 2012 6:02 pm
by khisanth
Got my Pi up and running with the standard Debian "squeeze" build and am using a 32GB SD card no problem. However I noticed that the install has not used the whole card and there is still 28GB sitting there not belonging to a partition.
Whats the best way to resize the existing partitions and which one should I resize? CLI or GUI I am happy either way.
cheers
Re: Resizing partitions
Posted: Tue May 29, 2012 6:07 pm
by Joe Schmoe
The best way is to use fdisk to delete and recreate the partition "in place". There is a video floating around telling how to do it.
I really think this is the bet way - even though it is kinda like walking a tightrope blindfolded - because the alternatives (using the GUI and something called "gparted") always seem to ensnare people in su/sudo messes.
Posted: Tue May 29, 2012 6:08 pm
by spurious
what operating system are you using on your PC?
@Joe.. I tried the in place fdisk and got corruption.. I find running Linux in VMWare and connection to the physical SD card.. then using fdisk is more stable.
Posted: Tue May 29, 2012 6:11 pm
by Joe Schmoe
spurious wrote:what operating system are you using on your PC?
Oh, yeah. If you have another machine and can do it there, then of course, that's better.
But people want to do it on the Pi itself.
And, of course, trying to End User Support people doing it on another machine - well that opens up whole other cans of worms...
Posted: Tue May 29, 2012 6:24 pm
by nick.mccloud
See half way down this page:
http://elinux.org/RPi_Easy_SD_Card_Setup
Works for me, done it several times.
Posted: Tue May 29, 2012 7:04 pm
by khisanth
Windows 7, but have a Debian install too
Posted: Tue May 29, 2012 7:39 pm
by khisanth
All done! Did it on the Pi itself and went smoothly.
thanks peeps :D
Posted: Thu May 31, 2012 7:49 pm
by Harrkev
Quick story: I tried using "gparted" and the latest Ubuntu (running from a USB drive) to move/resize partitions, and it always crashed. Using the command-line "parted" instructions in the Wiki worked fine for me and opened up my 16GB card.
Posted: Fri Jun 01, 2012 3:28 pm
by philipm
nick.mccloud wrote:See half way down this page:
I just tried this (running parted on the command line off an Ubuntu system) and it was unhappy when I tried to change partitions with messages like:
Error: Error informing the kernel about modifications to partition /dev/sdc1p1
-- Invalid argument. This means Linux won't know about any changes you made to
/dev/sdc1p1 until you reboot -- so you shouldn't mount it or use it in any way
before rebooting.
Did I do something perhaps inadvertently to make it mount the file system again? I'm running dd again since it didn't leave the device in a happy state.
Posted: Fri Jun 01, 2012 4:51 pm
by strawberrytau
Is there any way of doing this on a Mac (other than using a gparted LIVE CD). I own a MacBook Air with no CD Drive!
Posted: Fri Jun 01, 2012 5:30 pm
by nevyn
I followed the tutorial here: http://www.youtube.com/watch?v=R4VovMDnsIE&feature=plcp Using this method you resize the partitions on the Pi and not on your laptop/computer.
I resized the partition to the full SD capacity. Used this method twice with Debian and it worked on both occasions.
Regards,
Mark
Posted: Sat Jun 02, 2012 12:47 pm
by gordon@drogon.net
Lots of good replys there - I'll add another:
https://projects.drogon.net/raspberry-p ... al-setup1/
Theres a few extra bits & pieces there too.
-Gordon
Posted: Sat Jun 02, 2012 8:51 pm
by guleesh
I'm glad some people are having success with resizing the partitions on the RaspberryPi itself.
For me it just won't work.
Here's what I did : (maybe someone else has had success with resizing the partition in Archilinux and can help out)
I followed instructions here http://elinux.org/RPi_Easy_SD_Card_Setu ... spberry_Pi
The are only 2 partitions on archlinux img - so I just adapted the instructions and deleted then recreated partition 2.
The recreated partition started at same block as the the partition I had just removed.
I used the default for the end block. This seemed to create the partition using all available space on the sd card - about 14.9 GB
All seemed to go well.
I did see an error message when writing the partition, it said something about the partition will not be usable by kernel until reboot or reloading some kernel modules.
I thought it was fair enough - and that the instructions had said that the partition will not be useful until rebooting anyway - so I rebooted.
After reboot I was unable to log in.
I was presented with a login: prompt but after typing root - the prompt would just immediately popup again.
Eventually giving me this error message
"Unable to determine your tty name"
I'm going to fire up my old ubuntu laptop and try parted, although I would really like to be able to get htis working for Archlinux on the RaspberryPi - since in theory having to have other operating systems around - seems to defeat the point.
Also - perhaps there is another approach where the .img file could be manipulated to take up 8GB or 16GB ?
Does anyone know if this is doable ?
I'm on OS X (which is the basket case of *nix distros) so if anyone knows how to resize it using some OS X tools then do tell.
