logmein .deb
Posted: Mon May 28, 2012 8:38 pm
by BigJeffIE
Hi folks,
Got my Raspberry Pi in the post today... wooohhoooooo....
I've downloaded the beta logmein.deb file into my /home/pi folder.
I'm trying to install it with
sudo apt-get install logmein.deb
but it says it can't find the file.
What am I doing wrong :?: :roll:
Thanks.
Re: logmein .deb
Posted: Mon May 28, 2012 8:43 pm
by JeremyF
You should use
dpkg -i logmein.deb
to specify a local file
Re: logmein .deb
Posted: Mon May 28, 2012 8:46 pm
by andyl
[quote="BigJeffIE"]Hi folks,
[quote]
You are just a bit confused about what commands do.
apt-get (in fact all the apt commands) interact with a repository of software. So you are asking apt-get to look through the standard application repository for something called logmein.deb and it isn't found (surprisingly enough).
To install a local .deb file you use the following command
sudo dpkg -i logmein.deb
if you want to get rid of it later use
sudo dpkg -r logmein
Beaten by JeremyF but I will post my reply as it contains a bit more information.
Re: logmein .deb
Posted: Mon May 28, 2012 8:48 pm
by BigJeffIE
Great, thanks for the quick reply Jeremy...
That worked :)
Re: logmein .deb
Posted: Mon May 28, 2012 8:49 pm
by BigJeffIE
and thanks Andy :D
Re: logmein .deb
Posted: Tue Aug 21, 2012 8:13 pm
by castro145
BiggJeffiE,
Where did you find the logmein.deb? This is a logmein client? I'm assuming you did this so you have a always on PC accessible from the web?
