Wed Jan 29, 2014 3:17 pm
I cannot write a complete tutorial for this for you, including all the steps you need to take. The first question is, do you know how to write bash scripts? I can think of one possible way to get xdotool to emulate your double click every 15 seconds - one is to have a script running that issues the double click every 15 seconds.
But, do you know how to write scripts?
The second thing is you need to install and write the command that will emulate that click, and test whether it will work in midori. Some applications do not cooperate with xdotool, and the only way to know is to install it and try running it. did you say what operating system you are running? I am not sure whether it is available in your repository.
No sense writing a script unless xdotool works in midori! There is another command that is more basic that also emulates clicks, but I think xdotool is better as it may have more tutorials out there. I don't recall the name of the other command that does the same thing.
if you use apt-get to install stuff, try "apt-get xdotool" to see if it is available precompiled.
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
