techforay
Cant remove Scratch from pi
Fri Jan 24, 2014 12:24 am
I am using a command sudo apt-get remove Scratch and i get the following:
Reading package lists... Done
Building dependency tree
E: Unable to locate package Scratch
When I do a ls command i can see the Scratch directory. What am i doing wrong that gets the above error?
AndyD
Re: Cant remove Scratch from pi
Fri Jan 24, 2014 1:31 am
I am pretty sure it is case sensitive. You need to know the name of the package, not the program. In this case:-
sudo apt-get remove scratch
techforay
Fri Jan 24, 2014 1:22 pm
That was the problem but I was assuming since the directory was capitalized the command should be also. I was wrong. I removed and reinstalled but it still seems to lock up when I execute. Any suggestions?
achrn
Fri Jan 24, 2014 1:49 pm
So is the actual problem not that you want to remove Scratch, but that you want to use Scratch, and it's not working for you?
techforay
Fri Jan 24, 2014 1:51 pm
Yes sir
